Alpine Mrd-M1005 1000W
Amplificatoru are si DSP cu corectie de timp , LP,Hp , Phase etc . Indicator de temperatura , voltaj , merge si la 1ohm pe proba :lol:
pret 200E Class D mono subwoofer car amplifier RMS Power Rating: 500 watts x 1 chan. at 4 ohms 1000 watts x 1 chan. at 2 ohms Internal, variable-speed cooling fan Amp Link for single-cable hookup to compatible Alpine receivers STAR Topology for cleaner sound Bass Engine® features: Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope Selectable subsonic filter (off, 15Hz, or 30 Hz) Parametric EQ variable from 30-160 Hz, ±12 dB Bass Compensator enhances low-end definition Top-mounted digital control center with cover CEA-2006 Compliant MOSFET power supply and output stages Preamp outputs Time correction 0-10 milliseconds in 0.1ms steps Phase adjustment 0-180° Turn-on delay 4-gauge power and ground leads Extra-large terminals Dimensions: 13" L x 8-11/16" W x 2-5/16" H |
Re: Alpine Mrd-M1005 1000W
800ron !:D
ultimul pret la ea?
revine la vanzare 700ron ! :D
650ron 0752511397
s-a vandut, multumesc 4tuning !
| All times are GMT +2. The time now is 09:36. |
