-   Piese BMW de vanzare (https://forum.4tuning.ro/641-piese-bmw-vanzare.html)
-   -   BMW M5 E39 (https://forum.4tuning.ro/641-piese-bmw-vanzare/345484-bmw-m5-e39.html)
Provenzano 13-11-12 22:12
BMW M5 E39
7 Attachment(s)
Vand volanta usurata UUC MOTORWERKS
Produs-NOU-
BMW E39 M5 and Z8
Details: 13.5lb reduction is flywheel weight for faster acceleration and better throttle response.
THE FLYWHEEL:
Built with the same level of technical sophistication and quality that earned UUC a European Car magazine "Select Gear Top 10" award for best products of 2003, and also the SFI race-spec certification, this is simply the best quality flywheel that can be built. Construction details include CNC machined 6061-T6 aluminum disk with replaceable 1050 steel friction surface (suitable for any clutch material, including race-only sintered iron). Friction surface retaining bolt pattern is computer-designed for optimum strength and load-bearing. Correct V8 starter ring and ignition trigger ring for perfect operation.
Pret: 1000$
contact:[email protected]
