Vand Power Acoustik Bamf 5500/1D
Detalii: 5500W Max Monoblock Class D Amplifier Car Amplifier RMS Power Rating: 4 ohms: 1700 watts x 1 chan. 2 ohms: 2300 watts x 1 chan. 1 ohm: 3200 watts x 1 chan. Max power output: 5500 watts x 1 chan. Fully regulated PWM power supply Wired remote bass level control included System distress indicator Four way protection circuit Adjustable Tuned Bass EQ (0-18 dB Bass Boost) Hi-Speed digital circuitry Full selectable crossover (HI,Full,Low 1-Ohm Stable Full selectable crossover (HI,Full,Low) Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation Platinum-plated RCA level inputs Platinum-plated screw terminals Variable low-pass filter (40-200 Hz, 12 dB/octave) Variable subsonic filter (20-50 Hz) Variable subwoofer EQ @ 45 Hz Frequency response: 20-200 Hz Signal to Noise Ratio: 100 dB Dimensions: 16-7/8"L x 8-1/4"W x 2-1/8"H 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier. Functional 10/10 Estetic 8/10 Poze: Attachment 2566661Attachment 2566662 Pret:200E Negociabil |
Re: Vand Power Acoustik Bamf 5500/1D
Vandut. Se poate inchide. Multumesc 4tuning pentru gazduire
