-   -   Rinspeed eXasis (https://forum.4tuning.ro/18-masini-tunate/33389-rinspeed-exasis.html)
RoSonic 14-02-07 18:58
Rinspeed eXasis
Rinspeed eXasis
Rinspeed AG a creat inca un concept senzational, numit Rinspeed eXasis, ce va debuta la Geneva Motor Show.
TECHNICAL DATA
Measurements
Length 3'700 mm
Width 1'960 mm
Height 1'284 mm
Wheelbase 2’500 mm
Track front 1’700 mm
Track rear 1’700 mm
Ground clearance 325 mm (245mm)
Empty weight approx. 750kg
Vmax
Top speed 210 km/h
Acceleration 0-100 km/h approx. 4.8 sec
Engine
Engine family Weber Motor MPE 750 Turbo
Displacement 750 ccm
Stroke 66 mm
Bore 85 mm
Cylinders 2
Valves 4
Compression ratio 9:1
Power output 150 PS
at 7500 /min
Max. torque 150 Nm
at 4500 /min
Type of fuel Ethanol
Propulsion
Power train Rear wheel drive
Gearbox Manual sequentiell
Gears 6
Suspension
Chassis Aluminium
Body Plastic
Seating capacity Recaro Innovation
Front brakes 380 mm - 6 piston
Rear brakes 355 mm - 4 piston
Front suspension Double wishbone
Rear suspension Double wishbone
Dampers/springs KW automotive
Steering Rack & pinion
Tires
Front tires 265/30-22
Front wheels AEZ 8.5 x 22“
Rear tires 295/25-22
Rear wheels AEZ 11 x 22“
Bobby boss 14-02-07 19:46
Re: Rinspeed eXasis
prin dizain si cam aduce aminte de stilu ala roster mai vechi asa
Cristy@n0_crs 14-02-07 19:50
Re: Rinspeed eXasis
ciudata masina :D
® Al3cS ® 14-02-07 20:06
Re: Rinspeed eXasis
Urata "masina" dak ii pot spune asa :(
Todorutz 14-02-07 20:09
Re: Rinspeed eXasis
tehnologie de viitor combinata cu stilul retro....ar merge o masinutza deasta vara pe faleza la mare :P
Tzus 14-02-07 20:31
Re: Rinspeed eXasis
Hotroad combinat cu un design ***urist...a iesit ceva dragutz...nimic mai mult.
Andreus 14-02-07 21:29
Re: Rinspeed eXasis
Vin shi eu cu o completare....sper sa nu se supere nimeni :???: Denumit eXasis, acesta oficializeaza reintoarcerea structurii de caroserie monococa in industrie si imprumuta din Formula 1 suspensiile si bratele de prindere ale rotilor asezate in exterior.Motorul biciclindric pe bioetanol dispune de o cilindree de 750 cmc si scoate un maxim de 150 de cai putere.
sebaaa 14-02-07 21:43
Re: Rinspeed eXasis
motorul este adevarata realizare la ea , in cazul asta
Mendex 15-02-07 21:01
Re: Rinspeed eXasis
e in acelasi stil cu un buggy
bizkuite 16-02-07 00:22
Re: Rinspeed eXasis
performantele sunt de invidiat, tinand cont de motor si greutatea redusa
caroseria e de belea, transparenta... ;)
z3r0m3CSL 16-02-07 13:36
Re: Rinspeed eXasis
Da ii TURBO motorul da tot ii mult 150 CP da imi place arata bine.
ROSSI 46 16-02-07 16:53
Re: Rinspeed eXasis
au facuto k sa ce?....shtiam k se poate....shi pretzul o sa fie cat al unui murcielago??...
Cobra_razvy7 17-02-07 15:39
Re: Rinspeed eXasis
cam ciudata masina...ma intreb oare cum vede pers din spate in fata??
Seat_TDI 18-02-07 01:12
Re: Rinspeed eXasis
nu imi place,nu prea arata a masina,mai degraba seamana cu o carutza cu multi cai
alex-mishu 19-02-07 16:35
Re: Rinspeed eXasis
Perfect de acord cu tine...
O masinarie nashpa rau..
