PIESE C20 LET/XE
Planetare C20let--45E
Ambreiaj (Placa de presiune) C20let-30E Volanta C20let-30E Disc ambreiaj C20xe marca Luk in stare f buna--25E Bord computer C20xe-25E Fuzete C20let impreuna cu discuri si etrieri-75E Alternator fulei lata C20let/xe-35E Electromotor C20let/xe/ne-35E capac delco impreuna cu Fise-25E Pompa Olei C20let/xe-50E Capac culbutori C20let/xe-30E Capac distributie C20let/xe-25E Motoras relanti C20let/xe-20E Vibroken C20let-30E Timonerie C20let F28-50E Pompa servo fulie lata-30E Caseta de directie C20let/xe/ne-45E Radiator ulei impreuna cu repartitor C20let/xe-30E Radiator Apa impruna cu interculer C20let-35E Sfera 4x4-35E Calculator 4x4-20E Debitmetru C20xe-25E Arcuri fata spate-30E Telescoape fata Calibra Vectra-30E Senzor presiune ulei-25E Stopuri calibra x 2--15E Radiatoare caldura calibra vectra--15E si AC 15E Usi calibra--15E Fata de usa(calibra) din dr in stare perfecta--10E Aripa(calibra) dr fata--12E Tampoane motor calibra/vectra c20xe/ne--12E bucata Motorase (centralizare) dela usi impreuna cu portbagag si buson de rezervor-25E Pistoane si biele c20xe fara urme fara zgarieturi-100 E ------ si..... multe ........Tel -0749282029 |
Re: PIESE C20 LET/XE
Radiator apa C20xe/ne/let la 100 de lei + ventilator (thermocupla) la 50 de lei.
uuuuup
YAPPPPP
cutie f20 4x4?
serpisorii de c20xe ii ai?
poza si pret, te rog
salut o poza cu electroventilatorul , pret arcuri stock spate, ce amperaj are alternatorul . multumesc
Fuzete C20let impreuna cu discuri si etrieri-75E Alternator fulei lata C20let/xe-35E capac delco impreuna cu Fise-25E Pompa Olei C20let/xe-50E Capac culbutori C20let/xe-30E Capac distributie C20let/xe-25E Motoras relanti C20let/xe-20E Vibroken C20let-30E Timonerie C20let F28-50E Pompa servo fulie lata-30E Radiator Apa impruna cu interculer C20let-35E Sfera 4x4-35E Calculator 4x4-20E Arcuri fata 25E Telescoape fata Calibra Vectra-30E Senzor presiune ulei-25E Stopuri calibra x 2--15E Radiatoare caldura calibra vectra--15E si AC 15E Usi calibra--15E Fata de usa(calibra) din dr in stare perfecta--10E Aripa(calibra) dr fata--12E Tampoane motor calibra/vectra c20xe/ne--12E bucata Motorase (centralizare) dela usi impreuna cu portbagag si buson de rezervor-25E Radiator apa C20xe/ne/let-25E Ventilator(thermocupla)-14E Pistoane(Forjate) si biele c20xe fara urme fara zgarieturi-100 E ------ si..... multe ........Tel -0749282029 |
Alternator 70A cu fulie lata(Pentru motor cu AC si fara AC) - 35E
Alternator 55A cu fulie ingusta(Pentru motor fara AC) - 25E Pompa servo cu fulie lata - 25E |
Cutie F28 ai ?
pompa benzina exterioara LET ?
| All times are GMT +2. The time now is 14:54. |
