Vand amplificator !
GTA 2 MKII Amplificator
Putere (W) In functie de Ohm si difuzoare Specificatii Max. Power 400 watts Max. Power@4 ohms 2x120 / 1x400 watts Max. Power@2 ohms 2x180 watts RMS Power@4 ohms 2x60 / 1x180 watts RMS Power@2 ohms 2x90 watts Number of channels 2/1 ch Class A/B Frequency response 10 - 30000 Hz Signal/noise ratio > 90 dBA Distortion factor at nominal power < 0.05 % Input impedance > 10 kOhms Input sensitivity 0.1 - 8 V Stability 2 ohms (4 ohms bridged) Low-pass filter 50 - 250 Hz (12dB/Octave) High-pass filter 80 Hz (12dB/octave) Subsonic Filter - Bass Boost 0 - 12 dB at 45 Hz Inputs 2x RCA Outputs 2x speakers Line-out 2xRCA Dimensions 190 x 56,5 x 260 mm Tel:0753617899 - RUF Pret: Negociabil - astept oferte, fara schimburi ! |
| All times are GMT +2. The time now is 13:37. |
