-   Alte Anunturi Piese (https://forum.4tuning.ro/524-anunturi-piese.html)
-   -   SISTEM AUDIO COMPLET (https://forum.4tuning.ro/524-anunturi-piese/3296-sistem-audio-complet.html)
Hondarul 14-01-05 16:18
6 Attachment(s)
Sistem Audio american, adus personal din SUA.
Amplificator woofer
2 canale Blitz Audio 2400 W maximum power, 600 W rms bridge, telecomanda, neoane albastre, Variable Bass Boost
Power On Led Indicator
Variable Hi/Low Electronic Crossover Network
Variable Input Level (Gain) Control
Remote Bass Boost
Thermal/Overload/Short Circut Protection
Stunning New Design With Two Neon Accent
Tubes On The Top Of The Amp.
Amplificator boxe
4 Channel Amplifier
4 x 100 Watts Output
400 Watts Total Output
Variable Gain Control
Remote Turn On/Off
Hi/Lo Level Inputs
Power On Indicator
LED Protection Indicator
S/N Ratio: >80dB
THD: <0.5%
Frequency Response: 25Hz-20kHz
Thermal & Short Circuit Protection
Dimensions: 2\"H x 11\"W x 9.2\"L
Boxe
Fatza: Rockford Fosgate Power Series coaxiale 5.25\" 60 W rms
Spate: Rockford Fosgate Power Series coaxiale 6.50\" 75 W rms
Subwoofer
Subwoofer AUTO profesional Power Acoustik FBX Series de 15\", 1600 W maximum power, 800 W rms, two pieces, Die-cast Aluminium Basket, Blue finish with Diamond cut, Non-pressed paper cone, Large foam rubber surround, 1-piece rubber gasket, Black Spider, Woven tinsel lead through spider, Heavy Duty Conectors, Dual 4 ohm voice coil. SPL: 93dB, magnet size: 15\" - 290oz, voice coil size: 2,5\", rms power: 800 W, Max power: 1600.
+CUTIE DE TRANSPORT DIN MDF.
Incinta
Cutie bands-pass din MDF de 21 mm, profesionala, 2 porturi, 4 conectori auriti, 2.0 cubic feet, 35 Hz.
Condensator
Lanzar cu neoane albastre, 2.4 Farad, digital, display albastru, kit de prindere.
Cablaje
Kit profesional complet pt 2 amplificatoare Scosche E-Fx + cablu Scosche pt boxe.
Toate produsele sunt noi, aduse pentru uz personal, nefolosite niciodata. Cutia cu wooferul nu-mi incape in masina (trebuie sa rabatez bancheta) si lipsa banilor - motivele vanzarii.
Pret total pe internet: ~1000 $ + taxele aferente
Greutate totala: ~85 kg
Pret de vanzare: 1000 Euro nediscutabil (eventual schimb cu altceva).
Pentru alte detalii: 0721922230 Vali
ZooM-ZooM 14-01-05 23:12
Oooohh!!! chilipir :) dar eu iti urez totusi bafta la vanzare...nuj cine o sa il ia pe tot :)
eventual in rate :))
bafta
Hondarul 15-01-05 10:04
Pai nu e obligat nimeni sa-l ia... Daca nu-l dau, il voi pune pe viitoarea masina, care sper sa fie mai incapatoare.
X-Ray-Eyes 08-02-05 00:59
Te-ai mai gandit daca vinzi \" piesele\" si separat ?
Eu iau 3 dintre ele daca te intereseaza.
