Vand Alpine PMX F640
Vand Alpine PMX F640 in perfecta stare de functionare , nu este zgariat , lovit sau reconditionat.
Attachment 2482882 Amplificator auto Alpine General Tip amplificator : Clasa-A/B Canale : 4/3/2 Sursa : DC-DC PWM Sursa : MOSFET Placa de baza : Circuite STAR Protectia : suprasarcina , supratensiune , protectie termica Indicator de putere : LED albastru montat deasupra Intrare RCA Intrare nivel inalt Crossover: Selectabil Low-Pass / High-Pass Connectori : Gold Plated Input, Output, Power and Speaker Terminals Pre-Amp Stage: Discrete SPECIFICATII Putere Putere totala : 640W Puterea RMS Pe canal la 4ohms (1%THD+N): 4 x 50W Pe canal la 2ohms (1%THD+N): 4 x 75W In punte la 4ohms (1%THD+N): 2 x 150W Setarea sunetului Frecventa crossover (Fix, OFF/LPF/HPF Selectable) 1/2 ch: 80 Hz (-18dB/oct) Frecventa crossover (Fix, OFF/LPF/HPF Selectable) 3/4 ch: 80 Hz (-18dB/oct) EQ (egalizator): Bass EQ Dimensiuni Baza: 270 mm x 60 mm x 242 mm General Consum: 14.4 V DC (11 V to 16 V) Sensibilitate de intrare : 0.2 - 4.0 V (RCA IN) Impedanta intrare : RCA IN 10k ? / SP IN 10k ? Raspunsul in frecventa: 10 Hz - 50 kHz (+ 0,-1 dB) Impedanta difuzoarelor : 4 sau 2 ohmi Raport semnal / zgomot: 90 dB Greutate : 3.0 Kg Pret 350 RON negociabil |
Re: Vand Alpine PMX F640
salut...daca mai ai statia...zi mi si mie prin pm care este ultimul pret...as vrea sa fac o investitie si amplif-ul asta pare cel mai potrivit...mersi...paul
Vandut
| All times are GMT +2. The time now is 10:32. |
