DEZMEMBREZ MAI MULTE OPEL-URI
17 Attachment(s)
DE INCEPUT DEZMEMBREZ UN OPEL VECTRA A 2000 16 V BERLINA DIN '95 SI UN OPEL VECTRA A 1.6 GLS HATCHBACK DIN '90
FARURII MANUALE MODEL DUPA 93 GRILA ARIPA FATA CAPOTA FATA PORBAGAJ BARA FATA/SPATE USII FATA/SPATE BC (COMPUTER DE BORD FARA BUTON ) CONTACT CU O CHEIE BUTUC USA CU O CHEIE SCAUNE+BANCHETA FETE USI INTERIOR COAJA DE BORD (MODELUL CU AIRBARG) NEAGRA COAJA DE BORD (MODELUL FARA AIRBARG) ALBASTRA VOLAN CU AIRBAG VOLAN SIMPLU ORIGINAL DE VECTRA MANETA SEMNAL/STERGATOR COMUTATOR FAR MANETA SCHIMBATOR VITEZA CEASURILE DE BORD CONSOLA CALDURA MOTORAS AEROTERMA ANSAMBLU STERGATOARE CU MOTORAS STOP SPATE BANDOU PORBAGAJ SPATE COMPRESOR AC RADIATOR AC RADIATOR MOTOR PUNTE SPATE CU DISCURI ARCURII FATA/SPATE AMORTIZOARE FATA/SPATE ETRIERII FATA POMPA BENZINA ECU(CALCULATOR MOTOR X20XEV) DEBILMETRU CAPAC TACHETI CADRU MOTOR MACARALE GEAMURII ELECTRICE FATA+ COMANDA VAS ANTIGEL VAS LICHID PARBRIZ (CU MOTORAS) BRATE STERGATORII SAXOFON CU SONDA LANDA POMPA+SERVO FRANA ALTERNATOR ELECTROMOTOR POMPA SEVODIRECTIE CU FULIE LATA CE VA MAI INTERESEAZA INTREBATI PE PM SAU LA TEL PRETURII AVANTAJOASE !!! DATE DE CONTACT : 0768750145 |
Re: DEZMEMBREZ MAI MULTE OPEL-URI
salut, un contact complet cat face si daca se potriveste pe 1,8,te am salutat
jante de aliaj si cauciucuri ce dimensiuni au
PRET 300 DE LEI (toate patru jante + trei anvelope) DATE DE CONTACT : 0768750145 |
13 Attachment(s)
PRETURII AVANTAJOASE !!! poze: |
sal am vb la tel in legatura cu puntea spate cu discuri uite nr meu de tel 0762885215 astept un semn de la tine
Date de contact 0768750145 Up... |
pretul la difuzoarele opel care e pana la urma?
ceva jante 4x100 pe 15 ai?
oglinzi electrice si incalzite?
7 Attachment(s)
jante de aliaj 15" set cu trei anvelope 195/65/15 pret 300 lei Quote:
DATE DE CONTACT :0768750145 |
cat ceri pe oglinda?
salut cat vrei pe jentile de aliaj fara cauciucuri???
regards |
SE MAI ADAUGA DOUA AVELOPE 185/60/14 TRAYAL 82h APROAPE NOI PROFIL 7MM DOT 2010 PRET 200 LEI FIX DATE DE CONTACT:0768750145 UP... |
