Vand Amplificator DLS CA41
# amplificator cu patru canale
# clasa AB # putere la 4 ohm 4 x 70 W # putere la 2 ohm 4 x 125 W # putere in punte la 4 ohm 2 x 200 W # raspuns in frecventa: 10 Hz - 35 kHz # damping factor > 100 # s/n ratio, A-weighted > 100 dB # filtre canalele AB - HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10) # filtre canalele CD - HP: 15-500 Hz / 150 Hz - 5 kHz (x10) # grand bass filter 0-18 dB @ 25-80 Hz # dimensiuni 70 x 372 mm x 268 mm http://dls.se/en/car/prod.html?produkt=en_103 CA 41 is a powerful amplifier with power output of 4 x 70 Watts. With a mono bridge-connection, it puts out all of 200 Watts. - Built-in/switchable low pass and high pass filters. - Bass boost 25 Hz - 80 Hz 0-18 dB. - Built-in protection circuits shut down the amplifier in the event of overloads. - Hi level input with Auto start Use it for a front system and a subwoofer. - High level input with auto start. - RMS output power @ 13,8 V, 20Hz - 20 kHz Pret: 600 Lei 0768 837 671 sau pe mess: fastracingsonic (daca dati add specificati ca pt DLS) |
Re: Vand Amplificator DLS CA41
5oo lei
500 de lei e ultimul pret pe www.dlsshop.ro/produs/102 e 1,059.00RON
Statia functioneaza impecabil n-am avut niciodata probleme cu ea de nici un fel. Se pot lega 2 perechi de boxe(fata si spate) sau o pereche de boxe + subwoofer (cum am avut eu) Poze recente:arrow: cei drept nu e chiar foarte curata acum dar se va curata f usor, nu-s zgarieturi e doar praf si culori de pe bagaje cum am carat prin portbagaj si s-au frecat de statie se vede in poze eu am prinsa statia de bancheta in portbagaj mai multe detalii: http://dls.se/en/car/prod.html?produkt=en_103 |
A ajuns la mine (in stare impecabila).
Multumesc F.R.Sonic pentru seriozitate si rapiditate! |
| All times are GMT +2. The time now is 12:23. |
