Vand Amplificator DLS CA21
DLS Classic CA21
Amplificator 2 canale; Clasa AB; Putere nominala: 4 ohm (0,1% THD): 2 x 100W; 2 ohm (0,2% THD): 2 x 200W; Max output 4 ohm bridged: 1 x 350 W; Damping factor >100; Frequency response 10 Hz - 30 kHz; Input impedance, low level >10 kohm; Input impedance, high level 100 ohms; High level input with auto start Yes Low output (RCA output) Yes; Input sensitivity 0,25 - 5V; Grand bass adjustable frequency 25 Hz - 80 Hz; Grand bass adjustable gain 0 - 18 dB; Filter highpass /subsonic 15-500 Hz; Filter lowpass 50-500 Hz; Power consumption, idle 1,0 A; Fuse 2 x 25A; Greutate 4kg; http://dls.se/econtent/files/64/classicampeng03.pdf Pret FIX: 300 lei Contact: PM, [email protected] sau 0744 673 680 Motiv vanzare: upgrade; trec pe full active. PS Amplificatorul face parte din generatia 2007, adica pe vremea cand DLS inca facea scule serioase. Ampliful a fost cumparat de nou, si folosit doar in regim SQ pe difuzoare dls ms6a. |
Re: Vand Amplificator DLS CA21
se retrage de la vanzare
| All times are GMT +2. The time now is 15:59. |
