VAND Boxe OMNITRONIC
Model Omnitornic Control 5 + suporti perete.
* 2-way speaker-system * For a wide frequency range * Wide dynamic-range with almost linear frequency range * High-quality bass-system * Also perfect for decentral sound-surroundings * Wall-mounting also available Rated power: 75 W RMS Program power: 100 W Components: 8" woofer, 1" tweeter Connections: terminal Max. SPL (1 m): 90 dB Impedance: 8 ohms Frequency range: 40 Hz - 20 kHz Dimensions (H x W x D): 255 x 230 x 400 mm Weight: 6 kg Suportul de perete: * Wall/ceiling mounting for Control 5 * Very stable version * Inclination angle adjustable within approx. 45° * Fixation screw with tooth gear for absolutely tight grip * With eyelet for attaching the safety rope for norm approved installation Material: white steel Maximum load: 10 kg Dimensions (WxDxH): 110 x 200 x 260 mm Pret pereche boxe + suporti: 350 lei - negociabil ! Contact pe mesaj privat aici pe forum sau n e c h i f o r a n d r e i @ y a h o o . c o m (fara spatii intre litere) tel: 0723143858 Multumesc, |
Re: VAND Boxe OMNITRONIC
300 lei - negociabil ! |
300 lei !!! - negociabil ! |
| All times are GMT +2. The time now is 23:38. |
