-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Vand amplificator DLS ca31 (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/299582-vand-amplificator-dls-ca31.html)
giubau_v8 20-01-12 18:56
Specifications
Number of channels 3
Amplifier class AB
Output power in 2 ohm 2 x 90 W RMS
Output power in 4 ohm 2 x 65 W RMS
Mono sub channel 2 ohm 280 W
Mono sub channel 4 ohm 170 W RMS
Damping factor >100
S/N ratio, A-weighted >100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance >10 kohm
Input impedance, high level 100 ohm
Filters channel A & B HP: 50-150 Hz
Remote bass level control No
Filter sub channel Lowpass: 50 - 120 Hz + subsonic 25 Hz
Low level output No
Remote phase shift control No
Phase control for subwoofers 0-180 degrees cont. variable
High level input with auto start Yes
Power consumption (idle) 1A
Power consumption (max) 60A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 30 A
Dimension (W x D x H) 70 x 357 x 268 mm (2,92 x 14,06 x 10,55 inch)
Weight 4 kg ( 8,8 lb)
Se afla in stare foarte buna atat functional cat si estetic.
0765 425 347
500 ron
giubau_v8 02-06-12 12:11
Re: Vand amplificator DLS ca31
Numarul de telefon nu e valabil momentan...puteti sa ma contactati aici pe forum pentru eventuale detalii
lupuadrian 03-06-12 18:05
Mai e valabil??
giubau_v8 03-06-12 18:40
Originally Posted by lupuadrian (Post 5051092)
Mai e valabil??
Desigur.
