Mac Cyclone 6000 4x150 W
Vand statie auto Mac Audio,in stare de functionare.
Pret : 200 ron Y.M : sergiu_iuly18 Pozele sunt luate dp bazar dar la cerere fac poze reale. TECHNICAL DATA MAC CYCLONE 6000 Circuitry: Complementary push-pull output stage amplifiers Max output power 4 x 150 W or 2 x 300 W (4W) Rated output power (DIN 45324, 14.4V) 4 x 75 W or 2 x 200 W (4W) Rated output power, THD 65 dB Input sensitiviy RCA 400 mV - 4V / 20 kOhm Input sensitivity HIGH LEVEL 1 - 10V / 100 Ohm Signal/Noise ratio (IEC A) > 105 dB Power supply + 12 V Minus at ground Fuse 2x 25 A Dimensions (W x H x D) 350 x 50 x 281 mm Weight 4.15 kg |
Re: Mac Cyclone 6000 4x150 W
Vanduta ! se poate inchide/sterge.
| All times are GMT +2. The time now is 07:22. |
