HU: Pioneer DEH-1100MP vs Kenwood KDC-3051R vs Kenwood KDC-4051UR
Doresc sa stiu care din aceste HU sunt OK pentru un sistem neamplificat. Boxele actuale sunt niste Pioneer de 35W RMS, dar ma gandesc sa trec pe un Helix B62C.
Dupa specificatii, diferentele intre cele 2 kenwood ar fi doar partea de USB, insa niste baieti de la o firma care instaleaza des asa ceva imi spun ca 30W RMS are doar modelul cu USB - o fi adevarat? Pioneer parca are un gain mai bun si l-am gasit la jumatate de pret cat Kenwood cu USB. Nu ma intereseaza USB, sincer, pot merge pe oricare din ele. Nu stiu cat conteaza acei 8W in plus pentru niste boxe de 35 sau 50 W RMS. Sistemul va sta pe un Peugeot 206, care sta cam prost la capitolul insonorizare usi sau asigurarea unei incinte decente de compresie pentru o boxa... Pioneer: Audio Maximum power output ....... 50 W × 4 Continuous power output ... 22 W × 4 (50 Hz to 15 000 Hz, 5% THD, 4 W load, both channels driven) Load impedance ...................... 4 W (4 W to 8 W allowable) Preout max output level ....... 2.0 V Tone controls: Bass Frequency ................ 100 Hz Gain ............................ ±13dB Mid Frequency ................ 1 kHz Gain ............................±12 dB Treble Frequency ................ 10 kHz Gain ............................±12 dB Kenwood 3051: Audio Specifications Maximum Power 50W x 4 Output Power (DIN45324,+B=14.4v) 30W x 4 Preout Level 2000mV / 10kOhm, Preout Impedance ≤ 600Ohm Speaker Impedance 4Ohm ~ 8Ohm AUX Frequency Response 20Hz ~ 20kHz (±1dB) AUX Maximum Input Voltage 1200mV AUX Input Impedance 10kOhm Bass Tone Control 100Hz ±8dB Middle Tone Control 1kHz ±8dB Treble Tone Control 10kHz ±8dB Kenwood 4051: Audio Specifications Maximum Power 50W x 4 Output Power (DIN45324,+B=14.4v) 30W x 4 Preout Level 2000mV / 10kOhm, Preout Impedance ≤ 600Ohm Speaker Impedance 4Ohm ~ 8Ohm AUX Frequency Response 20Hz ~ 20kHz (±1dB) AUX Maximum Input Voltage 1200mV AUX Input Impedance 10kOhm Bass Tone Control 100Hz ±8dB Middle Tone Control 1kHz ±8dB Treble Tone Control 10kHz ±8dB |
| All times are GMT +2. The time now is 14:09. |
