[cumpar] Intercooler
Dimensiuni (sau cel putin apropiate):
core length 24" core height 11" core thickness 4" Intrare 3" Iesire 3.5" |
Re: [cumpar] Intercooler
E bun ?
Bar & Plate Intercooler Turbo 1 Side 24"X11"X3" 2.5" Inlet & Outlet Overall Length: 24" , Core Length:18", Height:11", Thickness:3", Inlet&Outlet:2.5" Compress Air Flow Rate:<600Cubic Feet/Min, Rated to 600 Max HP Working Pressure: 5~50PSI Pressure Drop:2~5psi@35psi; 0.2~0.5psi@15psi Hot Air Temperature:32°F~302°F (0°C~150°C) Material:100% Aluminum, Bar and Plate Design, Polished Construction: Machine Cut and Stamped, Hand Welded Net Weight:18 lbs Works for: Many Cars and Trucks |
Sau asa
Length 24" Core Length 18" Height 11" Thickness 3" Inlet 2.5" Outlet 2.5" Compress Air Flow Rate <600Cubic Feet/Min, Rated to~600 Max HP Working Pressure: 5~50PSI Pressure Drop 2~5psi@35psi; 0.2~0.5psi@15psi Hot Air Temperature 32F~302F (0C~150C) Material 100% Aluminum Design Bar and Plate Construction Machine Cut and Stamped, Hand Welded Finish Polished Net Weight 18lbs Works for Many Cars |
Nu e bun nici unul, sunt prea mici.
Imi trebuie miezul de 24" si grosime de 4", intrare/iesire minim 3". |
Asta e mai bun ?
3" Inlet&Outlet 25"x12"x3" Tube&Fin FMIC Intercooler Core Size 18"X11.5"X2.75" Overall Size 25"x12"x3" Inlet & Outlet, 3" Core |
Sau asa :
Product Description : Type Aluminum Alloy Front Mount Tube Fin Intercooler Core Application Universal Core Size 600mm x 300mm x 76mm / 24" x 12" x 3" Inlet and Outlet = 76mm / 3" Description 100% Brand New Only 6.6Kg Package Included Intercooler x 1 |
Imi trebuie miezul adica "core-ul" sa aibe 24"x11"x4", intrare iesire 3".
Ce pret are ultimul postat? |
850 ron ( transportul face 100 $ aproape din pacate nu am ce face ..... ) .
Trebuie grosime 4".
Anunt valabil in continuare. Singura diminesiune care poate sa difere de ce caut ar fi inaltimea - sa se incadreze intre 7.5" si 11". |
asta
TWIN TURBO SET U-P INTERCOOLER ( DUAL INLET & OUTLET) INTERCOOLER SPEC: bar & plate design for better cooling efficiency max horsepower capacity : 700hp+ core length 24" core height 11" core thickness 3" inlet / outlet size 4 end to end length 30 1/2" sau BAR & PLATE DESIGN HORSE POWER RATING : 300-900 core length: 24" core height: 12" core thickness: 4" inlet / out let size: 3" end to end length: 30.5" |
Primul e pentru twin-turbo, trimite-mi un pret pentru:
1599 RON ( transportul 200 $ inclus in pret ) .
squid, ai PM
Se poate inchide.
Multumesc |
| All times are GMT +2. The time now is 13:53. |
