Cumpar stop stanga E34 semnal alb, preferabil Hella
Cumpar stop stanga cu semnal alb pentru E34, nou sau s/h. Prefer Hella. Va rog postati oferte aici sau pe PM.
Re: Cumpar stop stanga E34 semnal alb, preferabil Hella
1- 1989-1995 BMW 5-SERIES E34 SEDAN 4 DOOR
100% Brand new in box, never used or tried on Come as a SET included right and left side(4 PC SET) Meet S.A.E. (Society of Automotive) / D.O.T. (Department of Transportation) requirement OEM quality and fitment Directly bolt-on with no modification require Professional installation highly recommended Item exactly the same as picture shown We also carry a lot different style or color, 2- 100% Brand New, Ready To Ship. ( Package Includes 2 PCS ) Voltage: DC 12V Specifications: 2x 1156(Ba15s) T25 12-LED ( High Power ) Bulbs Color: Xenon White Life Expectancy: 50000 hours Low Power Consumption Cross Reference: 1073 1093 1129 1141 1154 1159 1259 1459 1619 1651 1680 3496 5007 5008 500967 89 97 7506 7507 7225 7527 S25 P21W Application: Stop/Brake Lights Only (Please Check Our Parts Compatibility List To Confirm If The Bulbs Will Fit Your Vehicle) New LED (Light Emitting Diode) technology reduces power consumption from 38% to 90%. Easy install design (Professional install is always recommended). This Type of JDM LED Signle Filaments Bulbs Are Much Brighter and Colorful Than the Stock OEM Dull Yellowish Tungsten lamps. Since the nature of the item being offered might fit a large variety of different vehicle and fucntions, please make sure this is the correct application type of bulb before u placed the bid. Caution: Q: Why the LED Bulbs doesn't light up? A: Problem can be solevd by switch the bulb 180 degrees. Q: Why error code or hyper flashing occoured? A: If error code or hyper flashing occoured, the problem can be solved by adding proper resistors. Pret 100 RON 2 bucati , transport inclus in pret . 3 - 102 leduri SMD - Package Included: 2 x 1156 Super Bright LED Bulbs (Pair) - Condition: 100% Brand new in box.Ready to ship - Socket: 1156 Ba15s (Single Function) - These bulbs are replacements for use in your vehicle's: 1073 1093 1129 1141 1154 1159 1259 1459 1619 1651 1680 3496 5007 5008 500967 89 97 7506 7507 7225 7527 S25 P21W - Application: Stop/Brake Lights Only (Please Check Our Parts Compatibility List To Confirm If The Bulbs Will Fit Your Vehicle) - Color: Super bright white (6000K InGaN Cool White) - Number of LED (per bulb):102 pieces T20 3528 SMD LED chips (90 around & 12 forward) - 3528 SMD (Surface Mount Device) Specification: * consists of one light-emitting chip * dimension of chip : 3.5 x 2.8 mm * power: 0.08W/pearl - Voltage: DC 12V - Life Expectancy: 50000 hours - Benefits of the new L.E.D (Light Emitting Diode) technology: Long-lasting; low power consumption; high intensity; faster On/Off response time; much brighter and colorful than the stock OEM dull yellowish tungsten lamps - Easy installation designed (Professional Installation is Always Recommended). - Make by approved manufacturer with quality material. - Provide 60 days limited warranty and after selling service. - Caution: Q: Why the LED Bulbs doesn't light up? A: Problem can be solevd by switch the bulb 180 degrees. Q: Why error code or hyper flashing occoured? A: If error code or hyper flashing occoured, the problem can be solved by adding proper resistors. If it still doesn't work or fit, please contact us or ask for professional advise. 199 RON transport si toate taxele incluse . Daca te intereseaza altceva zi-mi pe privat anul de fabricatie al masinii si iti trimit altceva . Mersi . Pozele sunt in ordinea ( prima poza pentru nr. 1 ,etc. ) . |
