-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Cumpar amplificator auto (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/292310-cumpar-amplificator-auto.html)
cannavaro 03-12-11 16:30
2 Ohmi - 500 w rms.
0729337245
Sau mai exact mi-am luat 2 subwoofere in cutie ground zero titanium in total 1000w rms, si as dori o statie ptr. ele. Am inteles ca-mi trebuie o statie la 2 Ohmi cu 500w rms minim.
Astept ofertele voastre!
Yulllll 04-12-11 12:42
Re: Cumpar amplificator auto
Poate o statie la 1000 rms iti trebuie..daca ai doua subwoofere..500 rms fiecare..sau o statie pe 2 canale..sa scoate pe fiecare canal 500 rms la 2 ohmi..daca spui tu...statie de 500 monobloc nu te ajuta..STIMA
cannavaro 04-12-11 16:57
Am cumparat. Multumesc de ajutor!
Yulllll 08-12-11 14:43
Ce ai luat? STIMA;)
cannavaro 08-12-11 22:25
Sal
Am luat asa
Db master sra 4800
igma-delta Platform
Through Hole Technology
Double sided Epoxy Military Standard PCB
Center Path Technology(Patent Pending )
regulated Power Supply
"Full Mosfet" Power Supply&Output Stages
Dual 0 Gage Power Inputs
Dual 0 Gage Ground Inputs
0.5 Ohm Stable
14.4V Input Voltage
Output Power: Class-D Technology(Mono)
1 x 800 Watts Rms @ 4 Ohms
(Currunt Draw 60A)
1 x 1500 Watts Rms @ 2 Ohms
(Currunt Draw 130A)
1 x 2800 Watts Rms @ 1 Ohms
(Currunt Draw 240A)
sra4800.dlinked into 4Ohm x 1Channel
Delivers a Blistering 3200(RMS) Watts
sra4800.dlinked into 2Ohm x 1Channel
Delivers a Blistering 6400(RMS) Watts and
Some change!
Frequency Response: 20Hz-330Hz
Singnal to Noise Ratio(S/N): >90dB
Total Harmonic Distortion(THD): <0>700
Minimum Load Stability
For all Channels: 0.5Ohms
