-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Vand magnat edition two (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/287795-vand-magnat-edition-two.html)
giubau_v8 10-11-11 19:47
Amplificator Auto Magnat Edition Two
Amplificator stereo 2 canale
Frequency response 5 Hz - 50 kHz (-3 dB)
Max. power output* into 4 Ω 2x 150 W / 1x 500 W
RMS power output** into 4 Ω 2x 55 W / 1x 150 W
Max. power output* into 2 Ω 2x 250 W
RMS power output** into 2 Ω 2x 75 W
THD < 0,08 % (1 kHz)
Signal-to-noise ratio > 100 dB
Input sensitivity 0,4 ? 4 V
Dimensions (W x L x D) 221 x 57 x 236 mm
Input impedance 20 kOhms
Power impedance 12 V minus an Masse
Weight 2,1 kg
2 ohm stable
Toshiba power audio transistors
Encapsulated power and speaker connectors
Low level RCA outputs
Low impedance capacitors for the power supply
Max Power Preamp circuit generates an optimised driver signal in bridged mode operation
Bridge-/Tri-mode capability
Low pass 40-300Hz (12 dB per octave)
High pass 40-300Hz (12 dB per octave)
Bass Boost 0...12dB at 45Hz
Produsul este folosit , dar in stare perfecta de functionare, 10/10 , are cateva urme de folosire 9/10 as zice eu .
A miscat in punte un woofer mnc spidershoxx de 10'' daca are vreo importanta.
Pret 150 ron
Tel. 0765425347
Mai am si wooferul de vanzare, daca le luati impreuna, ofer si kitul de cabluri necesare gratuit
giubau_v8 12-11-11 12:41
Re: Vand magnat edition two
uppppppppppppp
giubau_v8 14-11-11 15:44
Ma incurca prin casa. Merge bine si pe difuzoare si in punte pe subwoofer. Nu a fost abuzata. Stare tehnica impecabila.
giubau_v8 16-11-11 12:52
uppppppppppp
Madalinrm 16-11-11 14:37
salut mai ai amplificatorul?
giubau_v8 16-11-11 14:48
Daca azi la 13:52 am dat un upp, inseamna ca il mai am :D
giubau_v8 16-11-11 18:22
Vandut, se poate inchide
