-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   VAND AMPLIFICATOR DLS CA41 (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/286451-vand-amplificator-dls-ca41.html)
Tibitzu 03-11-11 22:04
Se vinde un amplificator DLS CA41
Impecabil din orice punct de vedere 10/10.
Foarte puternic si sunet foarte placut.
Folosit in regim de SQ doar pe tweetere si pe medii.
Cumparate acum o luna de zile.
Se vinde in ambalaj original cu toate acesoriile de la producator.
La cerere se fac poze din toate unghiurile.
Accept orice proba in orice conditii.
Motivul vanzarii este ca nu il mai folosesc.
CA 41 is a powerful amplifier with power output of 4 x 70 Watts. With a mono bridge-connection, it puts out all of 200 Watts.
- Built-in/switchable low pass and high pass filters.
- Bass boost 25 Hz - 80 Hz 0-18 dB.
- Built-in protection circuits shut down the amplifier in the event of overloads.
- Hi level input with Auto start
Use it for a front system and a subwoofer.
- High level input with auto start.
- RMS output power @ 13,8 V, 20Hz - 20 kHz
Specifications
Number of channels 4
Amplifier class AB
Mono bridge mode 4 ohm 2 x 200 W RMS
Output power in 2 ohm 4 x 125 W RMS
Output power in 4 ohm 4 x 70 W RMS
Damping factor >100
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance >10 kohm
Input impedance, high level 100 ohm
Filters channel A & B HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10)
Filters channel C & D HP: 15-500 Hz / 150 Hz - 5 kHz (x10)
Grand bass filter 0-18 dB @ 25-80 Hz
Remote bass level control No
Low level output Yes
High level input with auto start Yes
Remote phase shift control No
Power consumption (idle) 0,7 A
Power consumption (max) 60 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 30 A
Dimension (W x D x H) 70 x 372 mm x 268 mm (2,92 x 14,65 x 10,55 inches)
Weight 4,2 kg ( 9,3 lb)
PRET: 690 LEI ( PRET IN MAGAZIN PESTE 1000 LEI)
TRIMIT IN TOATA TARA PRIN CURIER RAPID SAU POSTA ROMANA
DETALII AICI SAU PE PRIVAT
Tibitzu 07-11-11 15:23
Re: VAND AMPLIFICATOR DLS CA41
sus cu el....impecabil...nou...
Tibitzu 10-11-11 21:53
Tibitzu 15-11-11 09:52
Tibitzu 17-11-11 08:56
transport gratis sau mai fac o mica reducere...
Tibitzu 19-11-11 13:38
Perfect pentru difuzoare sau pentru subwoofere+ difuzoare sau orice configuratie vreti voi...
Tibitzu 21-11-11 20:59
Impecabil....
ktalyn28 21-11-11 23:17
Te intereseaza un Dls CA31+diferenta?
Tibitzu 22-11-11 08:53
Nu multumesc...
laurentiu88richi 13-12-11 12:44
un pret pt azi? :D
Tibitzu 13-12-11 13:29
Un pret pentru astazi este 670 lei ca sa iti scoti si tu transportul...:D...e nou nu pot lasa foarte mult la el...
Tibitzu 11-01-12 16:42
pretul revine la 690 lei...
Tibitzu 17-02-12 12:54
VANDUT SE POATE INCHIDE...MULLTUMESC...
