Vand amplificator phonocar
phonocar 564
4x120wsau 2x300watt Mono Watt Rms 150+150 Risposta in Frequenza 10Hz-30Khz THD (Total Harmonic Distorsion) <0,2% Signal noise ratio >96dB Imput High sensibility ( RCA) da 150mV a 5V Input Low sensibility: autoradio fino a 50Watt Max Load Impedance da 2 a 8 Ohm Power supply Volts 14,4 (da 10 a 15,6 Volts) Fusibili 2 x 20A CROSSOVER ADJUSTABLE 12db / Oct incrocio frequenze Hp/Lp regolabile da 40 a 200 Hz lafel casi la poza revin cu poza reala. pret 250 ron discutabil merge perfect id fazekasbiker |
Re: Vand amplificator phonocar
poza reala
transport gratuit.cu posta
valabil
valabil 240 ron urgent
200 ron pana wekend!
valabil 200 ron fix merge perfect
sau schimb pe alt model cu 2 canal pentru 1 subwoofer
sau schimb pe alt model cu 2 canal pentru 1 subwoofer/sau schimb pe subwoofer de 2 sau 4 ohm 30 cm
pret 230 ron |
valabil
vand urgent 190 ron fara trasport!
valabil 185 ron
vandut
| All times are GMT +2. The time now is 05:33. |
