vand kenwood
kenwood excelon kac x520
125 watts RMS x 2 at 4 ohms 250 watts RMS x 2 at 2 ohms 500 watts RMS x 1 at 4 ohms in bridged mode stereo or bridged mono output Tri-way capable (Tri-Way crossover required) infrasonic filter (15 Hz, 24 dB/octave) 50-200 Hz crossovers: 12 dB/octave high-pass, 18 dB/octave low-pass 12 dB bass boost variable from 40-100 Hz (expandable to 6/12/18 dB when connected to a Kenwood Excelon receiver equipped with BMS controls) Bass Management System preamp outputs fan cooling speaker short, low battery, thermal overload, and DC protection variable color indicator gold-plated terminals requires 4-gauge power and ground leads — wiring and hardware not included with amplifier 2" wide detachable terminal covers pret 430 ron discutabil merge perfect . |
Re: vand kenwood
Re: vand kenwood
vandut
| All times are GMT +2. The time now is 13:09. |
