BMW Z4 M coupe VS Porsche Cayman S
2006 Porsche Cayman S Performance & Efficiency Specs
-3,387 cc 3.4 liters horizontal 6 mid engine with 96 mm bore, 78 mm stroke, 11.1 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder -Premium unleaded fuel 91 -Fuel economy EPA highway (mpg): 28 and EPA city (mpg): 20 -Multi-point injection fuel system -16.9 gallon main premium unleaded fuel tank -Power: 220 kW , 295 HP SAE @ 6,250 rpm; 251 ft lb , 340 Nm @ 4,400 rpm 2006 Porsche Cayman S Handling, Ride & Braking Specs -Four-wheel ABS -Four disc brakes including four ventilated discs -Electronic brake distribution -Electronic traction control via ABS & engine management -Immobilizer -Stability control -Strut front and rear suspension independent with stabilizer bar and coil springs -Tire kit 2006 Porsche Cayman S Exterior & Aerodynamics Specs -Body color front and rear bumpers -Driver and passenger power heated body color door mirrors -External dimensions: overall length (inches): 171.6, overall width (inches): 70.9, overall height (inches): 51.4, wheelbase (inches): 95.1, front track (inches): 58.5, rear track (inches): 60.2 and curb to curb turning circle (feet): 36.4 -Front fog lights -Projector beam lens halogen bulb headlights -Luxury trim alloy & leather on gearknob, leather on doors and alloy look on dashboard -Black paint -Fixed rear window with defogger -Trunk/hatch spoiler -Tinted glass on cabin -Weights: curb weight (lbs) 2,954 -Windshield wipers with variable intermittent wipe 2006 Porsche Cayman S Interior Specs -12v power outlet: front and 2 -Air conditioning -Power + diversity antenna -Peripheral interior monitoring anti-theft protection -Front ashtray -Audio anti-theft protection: integrated in dash -Manufacturer's own RDS audio system with AM/FM and CD player CD player reads MP3 -Cargo area light -Cargo capacity: all seats in place (cu ft): 14.1 -Front seats cigar lighter -Clock -Coming home device -Computer with average speed, average fuel consumption and range for remaining fuel -Full dashboard console with open storage box , full floor console with covered storage box -Delayed/fade courtesy lights -Cruise control -Front seats cup holders pop out -Door entry light -Door pockets/bins for driver seat and passenger seat -External temperature -Floor covering: carpet in load area -Driver front airbag intelligent , passenger front airbag with occupant sensors intelligent -Bucket electrically adjustable driver and passenger seat with height adjustment and one adjustment -3-point reel front seat belts on driver seat and passenger seat with pre-tensioners -Front seat center armrest -Garage door opener -Lockable glove compartment -Two head restraints on front seats -Headlight control with time delay switch-off -Heated washer -Illuminated entry system -Low fuel level warning -Low washer fluid level warning -Remote power locks includes power windows and speed sensing -Power steering -Front power windows with two one-touch -Front reading lights -Rear fog lights -Rear view mirror -Remote control remote trunk/hatch release -Front roof airbag -Leather seat upholstery with additional vinyl -Seating: two seats -Service interval indicator -Front side airbag -Nine speaker(s) -Leather covered steering wheel with tilt adjustment and telescopic adjustment -Tachometer -Illuminated driver and passenger vanity mirror -Ventilation system with recirculation setting, micro filter and active carbon filter 2006 Porsche Cayman S Snapshot MSRP: $58,900 Bodystyle: 2-Dr Coupe Engine: 3.4L H6 Transmission: 6 Speed Manual Drivetrains: Rear Wheel Drive BMW Z4m coupe Bodystyles: 2-Dr Coupe; Engines: 3.2L Inline 6; Transmissions: 6 Speed Manual; Drivetrains: Rear Wheel Drive; 2006 BMW Z4 Performance & Efficiency Standard Features Hide - 3,246 cc 3.2 liters in-line 6 front engine with 87 mm bore, 91 mm stroke, 11.5 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder S54 - Premium unleaded fuel 91 - Fuel economy EPA highway (mpg): 24 and EPA city (mpg): 16 - Multi-point injection fuel system - 14.5 gallon main premium unleaded fuel tank - Power: 246 kW , 330 HP SAE @ 7,900 rpm; 262 ft lb , 355 Nm @ 4,900 rpm 2006 BMW Z4 Handling, Ride & Braking Standard Features Hide - Four-wheel ABS - Brake assist system - Cornering brake control - Four disc brakes including four ventilated discs - Electronic brake distribution - Electronic traction control via ABS & engine management - Immobilizer - Rear limited slip differential - Stability control - Strut front suspension independent with stabilizer bar and coil springs , multi-link rear suspension independent with stabilizer bar and coil springs - Tire kit 2006 BMW Z4 Exterior & Aerodynamics Standard Features Hide - Body color front and rear bumpers - Day time running lights - Driver and passenger power heated body color door mirrors - External dimensions: overall length (inches): 161.9, overall width (inches): 70.1, overall height (inches): 50.7, wheelbase (inches): 98.3, front track (inches): 58.5, rear track (inches): 59.7 and curb to curb turning circle (feet): 34.3 - Front fog lights - High pressure headlight cleaners - Projector beam lens Bi-Xenon headlights - Heat reflective glass - Luxury trim alloy & leather on gearknob, alloy on doors and alloy on dashboard - Gloss paint - Fixed rear window with defogger - Tinted glass on cabin - Weights: curb weight (lbs) 3,230 - Windshield wipers with automatic intermittent wipe and rain sensor 2006 BMW Z4 Interior Standard Features Hide - Air conditioning with climate control - Antenna - Front ashtray - Audio anti-theft protection: integrated in dash - RDS audio system with AM/FM and CD player CD player reads MP3 - Cargo area light - Front seats cigar lighter - Clock - Computer with average speed, average fuel consumption and range for remaining fuel - Full dashboard console , full floor console with open storage box - Delayed/fade courtesy lights - Front seats cup holders pop out - Door pockets/bins for driver seat and passenger seat - External temperature - Floor covering: carpet in load area - Driver front airbag with occupant sensors intelligent , passenger front airbag with occupant sensors and occupant switch off intelligent - Sports driver and passenger seat with height adjustment and thigh support - 3-point reel front seat belts on driver seat and passenger seat with pre-tensioners - Front seat center armrest - Glove compartment - Two height adjustable head restraints on front seats - Headlight control with time delay switch-off, dusk sensor and auto off with ignition - Heated washer - Illuminated entry system - Internal dimensions: front headroom (inches): 37.3, front leg room (inches): 42 and front shoulder room (inches): 52.5 - Knee airbags - Low fuel level warning - Low tire pressure indicator - Remote power locks includes power windows - Power steering - Front power windows - Front reading lights - Rear view mirror - Remote control remote trunk/hatch release - Leather seat upholstery with additional vinyl - Seating: two seats - Service interval indicator - Front side airbag - Ten speaker(s) - Leather covered multi-function steering wheel with tilt adjustment and telescopic adjustment - Tachometer - Driver and passenger vanity mirror - Ventilation system with recirculation setting, micro filter and active carbon filter |
Re: BMW Z4 M coupe VS Porsche Cayman S
10 Attachment(s)
nu mi-a mers sa fac poll , si nu inteleg de ce
cayman normal... cel mai frums porsche si... nu e bmw :rolleyes2
cayman for me too.
ce aiurea ca BMW a ajuns dintr-o marca pe care lumea o indragea o marca de care lumea se fereste. problema de imagine a marcii, design discutabil la toate modelele, preturi usor prohibitive pentru ceea ce ofera defapt, probleme de fiabilitate, si in Romania... problema mare cu service-ul. cam nasol! |
Si eu as merge pe Cayman , are acel ceva al unui porsche....
Imi place Caymanul enorm dar la limita aleg BMW-ul pt. ca e mai performant, mai ieftin si in plus masina pe care o conduc are aceasi motorizare (M3 E46) si sunt fascinat de motorul asta! Probabil daca as conduce porsche situatia ar putea fi alta!
as alege z4 m....
in primul rand ptr ca am mers .. ce-i drept.. in dreapta.. cu .. z4 m si .. m-a spart... apoi . . e o masina mult mai rara.. apoi . . e o masina mai ptr cunoscatori as spune .. un cayman s poate ajunge pe mainile oricum .. bla bla bla , si mai ieftina , si m , si etc... |
z4....pentru ca este un ///M.Felling-ul oferit de masina...cu totul deosebit...ceva de nedescris....are acel ceva...
porsche cayman....alaturi de boxter...singurele masini (de la porsche) care nu arata a porsche.... ///m-ul e altceva...nu e un simplu bmw....un ///m e pentru cine il 'simte'...e mai exclusivist......porsche...isi ia ""oricine"",doar e masina de fitze,insa putini merita. Disclaimer:acum poate multa lume o sa imi sara in cap ca sunt un pusti care n-are ce face....dar asa vad eu chestia asta.NU contest si nu voi contesta niciodata traditia,performantele si succesele porsche.una dintre cele mai 'tari' marci din lume(practic in top 10 cele mai tari masini sport din lume,deasupra la stingray,enzo si alte masini care au facut si fac istorie....pe primul loc e porsche).o legenda vie. ps:daca nu era vorba cayman probabil alegeam porsche(si da,sunt fan bmw). |
UNLORD, stiu din experienta si din experienta multora din posesorii de BMW din Romania, vezi bmwclub. Pe locul 3 la fiabilitate??? Unde? JD? Parca era pe ceva gen 7 sau 8. Ma indoiesc ca s-ar putea tine BMW asa de aproape de Lexus/Toyota si Honda. Problema cu service-ul nu se refera la preturi, mie mi s-au parut destul de decente, se refera cu lipsa profesionalismului in cele din Romania. Poti spune ca nu ai avut probleme la Bavaria?
Scuze, am vazut pe urma ca ai scris de marci europene. Posibil... |
Fiabilitatea nu e dezaustruoasa, nici pe departe. Este slaba doar PENTRU PRETUL PE CARE IL PLATESTI PENTRU MASINA.
as alege Z4 M pt cai mai diferit,ciudat, extravagant, si esti MAI remarcat decat cu un Porsche nu stiu cate Z3 coupe ati vazut prin romania, sincer Porsche este cam in fiecare oras in care exista un om cu bani, care cumpara firma si nu extravaganta:???:
as merge Z4 M APROPO CRED CA SUNT MAI RARE audi-urile s3 DECAT ferrari-urile LA NOI IN TARA:D |
Celor de la topgear le-a placut mai mult bmw-ul! Dar mie imi place la forma mai mult porsche si chiar daca e mai putin performant o sa il aleg!
Fara sa stau p ganduri... B.M.W... probabil pt k sunt fan B.M.W ..:D
Si yo sunt fan BMW dar acuma merg Porsche cayman :D
| All times are GMT +2. The time now is 15:33. |
