[VAND] Electronice si aparate AUDIO
Asadar, in cadrul acestui topic voi posta anunturile de vanzare a aparatelor audio care nu-mi mai folosesc.
Sunt din colectia stransa in decursul catorva ani. Mi-au placut o perioada, sunt in continuare incantat de fiecare, insa a sosit momentul cand ordinea prioritatilor se schimba. Nu voi deschide cate un topic pt fiecare intrucat sunt foarte multe. Toate aparatele audio expuse la vanzare sunt in stare tehnica buna/foarte buna, intretinute si servisate profesional. Pozele postate in cadrul anunturilor de vanzare sunt reale. Preturile sunt usor negociabile. Fara schimburi. tel 0722.766711 |
Re: [VAND] Electronice si aparate AUDIO
Tape deck AKAI GX-75 MKII
Made in Japan, model deosebit, stare foarte buna, tehnic si optic impecabil. Pret 150euro Caractersitici tehnice: Gold-plated RCA jacks 3 heads motor-drivencassette ejection Automatic tape type selector mechanism (ATS) Zero return function / Easy playback Record mute to automatically insert spaces FL level meters (15 segments) with peak level memory feature multiple switchable Echtzeitzähllaufwerk, resettable Display Off Calibration of the Aussteuerungspegels (normal / extended dynamic range) Tape Monitor (Monitor) Selector level display area (m Range) Title search (MS): 15 tracks forward and backward Dolby B-C / HX-Pro Switchable MPX filter Rec-Mute timer playback and recording large, multi-color digital display vibration and resonance-free construction (honeycomb-housing) Knob of Rec-Balance, Bias (bias), Rec Level adjustable, gold-plated headphone jack Silver Stands Frequency response (-20 dB recording): Pure iron band: 15 Hz to 22,000 Hz Chromium Band: 15 Hz to 21,000 Hz Iron oxide tape: 15 Hz to 21,000 Hz Power consumption: 22 watts Weight: 7.3 kg Size: approx 457 x 133.5 x 372 mm (width x height x depth) |
Receiver AIWA AF 3060
Functii tuner stereo + tape deck + amplificare, made in JAPAN. Stare buna, optic impecabil. Carcasa din lemn (stare perfecta), partea frontala metalica (impecabil). Vu-metre si iluminarea scalei perfect functionale, fara becuri lipsa/arse. Fara interventii sau alte probleme. Sunetul este deosebit, specific aparatelor vintage din gama AIWA, cu putere 2 x 28W RMS. Mecanismul deck-ului OIL DAMPED ELEVATION. Intrare pt 2microphones, cu mix. Pret 380lei |
Receiver RANK ARENA R-930
Model deosebit, stare foarte buna, tehnic si optic impecabil, carcasa din lemn, putere 2 x 25W, tuner AM/FM, dimensiuni 450 x 130 x 290 mm. Pret 270lei. |
6 Attachment(s)
Receiver TECHNICS SA-200
Caracteristici tehnice Putere 2 x 25W (8ohm), Power consumption: 300 W @ 120/240 V, Phono MM; Tape; AUX; Monitor, Inp. Sensitivity High Level: 180 (Tape 1, REC/PLAY); 150 (AUX) mV, Inp. Impedance High Level: 39 (Tape 1, REC/PLAY); 33 (AUX) kΩ, Frequency Response High Level: 20-20,000 (±0.5 dB) HZ, Signal/Noise High Level: 88/95 (8/4 Ώ, IHF A) db, Output Voltage Rec Out: 150 REC OUT; 30 REC/PLAY mV, Tone Controls: Bass/Treble, Loudness, Dimensiuni 430mm (w) x 142mm (h) x 300mm (d) . Greutate 8,2kg. Pret 390lei |
Receiver SUPERSCOPE R-1270 by MARANTZ
Carcasa din lemn, putere 2 x 70W, tuner AM/FM, 4 channel FM output, quadraphase, phono, aux, and tape in. Pret 270lei |
Receiver SONY STR-D265
Amplituner Stereo, digital, functionare impecabila, senzor telecomanda, tehnic si optic in stare foarte buna, putere 70W. Aparatul are intrari analogice, 30 memorii radio, filtru bass boost. Pret 380lei |
Receiver JVC RS-11
Made in Japan, stare foarte buna, tehnic si optic impecabil, led-uri semnal+vu-metru+stereo+fine tuning, loudness and high filter switches + headphone jack. Scala balance, volume, treble si bass cu slide. Putere 2 x 30W, tuner AM/FM. Pret 320lei |
Tape deck ONKYO TA-2570
Made in Japan. Stare tehnica si optica impecabila. Foarte bine intretinut. Carcasa metalica. Pret 300lei Caracteristici tehnice: Frontloading 3-Head Stereo Cassette Tape Deck with Dolby B + C, MPX Filter, Dolby HX Pro and Metal Tape Capability. AMCS (Automatic Music Control System). 4-Digit Digital Counter, Linear Tape Counter, Digital Peak-Reading Meters. Wireless Remote Control. |
6 Attachment(s)
Tuner ONKYO T-4650
Culoare argintiu, stare tehnica foarte buna, aspect excelent, made in JAPAN. Pret 265lei Caracteristici tehnice # Baujahre: 1989, 1990 # Farbe: silber, schwarz # Fernbedienung: über RI-System # Leistungsaufnahme: # Abmessungen: 435 x 92 x 366 mm (BxHxT) # Gewicht: 4 kg # Neupreis cca.: 598,00 DEM |
Tuner TECHNICS ST-8080
Tuner vintage stereo AM / FM, model deosebit, made in JAPAN. Pret 320lei Caracteristici tehnice: Tuning and signal strength indicators, variable output control : 0.6V to 1.4V, Tuning frequency range : 88 to 108MHz, Signal / Noise ratio : 75dB mono, Frequency response : 20Hz to 18kHz [+0.2dB / -0.8dB, variable out] 20 to 15kHz for fixed out, Total Harmonic Distortion [1kHz, 100% modulation]: Mono 0.15% / stereo 0.3%, Separation [1kHz]: 45dB 3.5dB [10kHz], Image rejection [98MHz]: 85dB IF rejection: 100dB, spurious response rejection: 95dB, AM rejection : 55dB, Carrier leakage : -65dB [19kHz, variable out], -70dB [19/38kHz, fixed out], Output levels : 0 to 1.4V, variable out, 0.6V fixed Dimensiuni: 450mm (w) x 140mm (h) x 367mm (d). Greutate 9,0kg |
Tuner TECHNICS ST-7300K
Made in JAPAN, in stare tehnica foarte buna, carcasa din lemn, partea frontala cu usoare zgarieturi. Dimensiuni 410 x 140 x 295 mm. Pret 180lei |
Tuner GRUNDIG ST-6000
Tuner stereo AM / FM , culoare argintiu, impecabil tehnic si optic, model deosebit, made in GERMANY. Pret 440lei Date tehnice: * Frequencies: FM: 87.50 - 108 MHz, MW: 510 - 1620 KHz * Response: 10 - 17.000 Hz -3 dB, 20 - 16,000 Hz -1 dB * Input Sensitivity: 0.5/18 microvolts (mono/stereo) UKW, 9µV MW * Distortion: <0.1 / 0.2% (mono/stereo) * Signal to Noise Ratio: 72/68 dB (mono/stereo DIN) * Channel separation:> 40 dB * Selectivity:> 60 dB * Equal wave selection: <1dB * Image Rejection:> 80 dB * IF Rejection:> 100 dB * AM-suppression:> 56 dB * Station Memory: 30 for both areas together * Digital frequency display * Signal strength indicator with 8 LEDs * Memory Scan * Antenna inputs: 75 ohms, 300 ohms, medium wave * Dimensions: 450 x 60 x 350 mm * Selling Price in Germany was: 1050 - DM/1980 |
Tuner GRUNDIG T-1000
Tuner stereo in stare foarte buna, tehnic si optic impecabil, carcasa din metal. Made in Germany. Pret 170lei. Date tehnice Super-Heterodyne (Super in general); IF-Freq 460/10700 kHz. Broadcast, Long Wave and FM. Alternating Current supply (AC) / 110, 220 Volt. Dimension: 450 x 110 x 305 mm. |
Tuner DUAL CT-1140
Tuner stereo, made in Germany, stare tehnica foarte buna. Carcasa metalica, partea frontala prezinta zgarieturi. Pret 185lei. Date tehnice Super-Heterodyne; IF-Freq 455/10700 kHz, Broadcast, Long Wave and FM, Alternating Current supply (AC) / 230 Volt. Dimensiuni 440 x 115 x 360 mm. |
| All times are GMT +2. The time now is 14:59. |
