Multifunctional Samsung SCX4521F
Vind multifunctional Samsung SCX4521F , imprimanta,fax,scanner,copiator laser .Aparatul este nou , putin folosit , il am de la un tip care are un magazin de componente IT , pe care-l credeam un bun prieten si caruia i-am dat o suma de bani sa-mi aduca un procesor INTEL D960 pe care n-a binevoit sa-l mai aduca si atunci ca sa-mi recuperez banii , i-am luat multifunctionalul .
Deci il vind sau il schimb cu un procesor INTEL D960 pe LGA775 .Astept oferte! [email protected] 0722375765 |
Re: Multifunctional Samsung SCX4521F
Caracteristici producator :
Print Method Laser Beam Printing Speed * Up to 20 ppm in A4 (20 ppm in Letter) Resolution 600 x 600 dpi First Print Out Time 11 seconds (from Standby mode) Emulation SPL(Samsung Printer Language) Memory Duplex Print N/A Copy Speed ** Up to 20 ppm in A4 (20 ppm in Letter) Resolution (Optical) 600 x 600 dpi Text, Text/Photo : 600 x 300 dpi Photo mode : 600 x 600dpi (Platen), 600 x 300dpi (ADF) Resolution (Enhanced) 600 x 600 dpi First Copy Out Time 11 seconds (from Standby mode) Zoom Rate 25~400% (platen), 25~100% (ADF) Multy Copy 1~99 pages Duplex Copy - Scan Compatibility Twain Standard, WIA Standard Method Color CIS Resolution(Optical) 600 x 600 dpi Resolution(Enhanced) 4800 x 4800 dpi Effective Scan Length 297 mm (11.7") Effective Scan Width 208 mm (8.2") Color Bit depth Internal : 24 bit, External : 24 bit B/W Bit depth 1 bit for Text mode, 8 bit for Gray mode Gray Scale 256 Levels FAX Compatibility ITU-T Group 3, ECM Applicable line Public Switched Telephone Network (PSTN) or behind PABX Modem Speed 33.6 Kbps Transmission Speed *** Approx. 3 seconds per page Compression Mode MH / MR / MMR / JPEG Scan Speed **** Approx. 3 seconds per page Resolution Max. 300 x 300 dpi Standard : 203 x 98 dpi Fine : 203 x 196 dpi Super Fine : 300 x 300 dpi Photo : 203 x 196 dpi Color : 200 x 200 dpi Memory 2 MB (Approx. 160 pages at ITU-T #1 Chart) Auto Dial Up to 100 Locations Paper Handling Input Capacity and Types 150-sheet Multi-purpose Tray (75 g/㎡, 20 lbs), 1-Sheet Manual Tray Output Capacity and Types 50-sheet Face Down (75 g/㎡, 20 lbs) Media Size (for Print) Legal,A4,Letter, Folio, Executive, JIS B5, A5, A6, Envelope6 3/4, 7 3/4,#9, #10,DL,C5,C6, ISO B5, Monarch Env 76 x 127 mm (3" x 5") ~ 216 x 356 mm (8.5" x 14") Media Size (for Fax and Copy) Letter, A4, Legal Media type MP Tray - Type : Plain Paper, Transparency, Labels, Card Stock, Envelope, Bond, Thick, Thin, Color Paper, Preprinted - Weight : 60-90 g/㎡ (16-25 lb) Manual Tray - Type : Plain Paper , Transparency, Labels, Cards, Envelopes - Weight : ADF Capacity 30 sheets(Letter / A4, 20 lb / 75 g/㎡) ADF Document Size Width: 142 ~ 216mm (5.6"~8.5") Length : 148 ~ 356mm (5.8" ~ 14.0") General Net Dimension (W x D x H) 438 x 374 x 368mm (17.2 x 14.7 x 14.5 in) Packing Dimension (W x D x H) Weight with Consumables 10.4 Kg Packing Weight 12.3 Kg LCD 2 line x 16 characters System Memory 16 MB Interface USB 1.1 (Compatible with USB 2.0), IEEE 1284 Parallel OS Compatibility ***** . Windows 98/Me/NT4.0/2000/XP, . Various Linux OS (via USB interface only) including Red Hat 8.0~9.0, Fedora Core 1~3, Mandrake 9.0~10.2, and SuSE 8.2~9.2 . Mac. 10.3 Warm-up Time Less than 35 seconds (from Sleep mode) Noise Level ****** Warm up : Less than 49 dBA Stand by : Less than 35 dBA Printing : Less than 53 dBA Coping : Less than 55 dBA Power Requirement 110 ~ 127 VAC, 50/60 Hz, 4.5A 220 ~ 240 VAC, 50/60 Hz, 2.5A Power Consumption Sleep Mode : 10 W (Energy Star Complient) Standby Mode : 55W Average : 350 W Operating Conditions Temperature : 10 ℃ ~ 32 ℃ (50 ℉ ~ 89 ℉) Humidity : 20 % ~ 80 % RH Duty Cycle, monthly Up to 4,200 pages Consumables Type Single Cartridge Yield 3,000 pages at ISO 19752 5% Coverage (Ships with 1,000 pages Starter Toner Cartridge) Code SCX-4521D3 Options Network Ethernet 10/100 Base TX (External) : ML-00ND Others N/A |
| All times are GMT +2. The time now is 11:26. |
