-   Sistemul Audio de pe Masina Mea (https://forum.4tuning.ro/384-sistemul-audio-masina-mea.html)
-   -   VW Polo 6n2 - denees (https://forum.4tuning.ro/384-sistemul-audio-masina-mea/273213-vw-polo-6n2-denees.html)
denees 10-08-11 23:20
8 Attachment(s)
In primul rand, tin sa salut toti pasionatii de pe aceasta sectiune!
Ma numesc Denis. Anul trecut, in vara, am achizitionat un Polo 6n2, 1.4 mpi; ca dotari: geamuri fata electrice, oglinzi electrice, 4 airbag-uri, trapa electrica etc.
Masina este de zi cu zi, de aceea i-am adus doar cateva modificari minore la exterior si la partea de sunet. Pe cea din urma doresc sa pun mai mult accent.
Cu permisiunea dvs., prezint vechiul sistem audio de pe masina:
- Acumulator: Stock 44Ah;
- Mp3 Player: iPod Shuffle;
- Amplificator: Raveland XAB 1200 - 2x60w + 1x200w RMS@4ohm;
- Mid-bass: Stock;
- TW: MB Quart Discus - 50w RMS;
- CrossOver: MB Quart Discus;
- Subwoofer: Macrom 10" - 250w RMS@4ohm;
- Conectica: Crunch (AWG 3, 100A ANL, RCA dublu ecranat).
Amplificatorul fiind in 4 canale, au fost aplificate atat difuzoarele cat si subwoofer-ul.
Intre-timp am vandut amplificatorul si subwoofer-ul, am schimbat player-ul cu un Alpine 9827RR si am cumparat un MB Quart Premium PAB 4100:
- 4-Channel Amplifier
- Focused mass aluminium heat sink
- RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
- MOSFET power supply
- Ultra-flexible and variable adjustable active crossover network
- Vario bass equalizer circuit up to +18 dB
- 24 dB subsonic filter
- Full range preamp outputs for easy daisy chaining of additional amplifiers
- MB QUART-Logo with illuminated red rectangle
- Wire concealing detachable end panels
- Frequency Response (-3 dB) : 10 Hz - 30 kHz
- Damping Factor: 200
- Signal To Noise Ratio: >95 dB
- THD: 0.05%
- Channel Separation: >70 dB
- Input Signal: 0.2 - 6.0 V
- Crossover S/W: LP.BP/Full/HP
- Variable Hi-pass / Subsonic Filter: 10 ~ 150 Hz
- Variable Low-Pass (mono 24 dB): 30 ~ 150 Hz Full range
- Bass Boost at 45 Hz: 1 ~ 9 dB
Am renuntat la subwoofer, motiv pentru care doresc sa antifonez usile fata si sa schimb difuzoarele. Aici, va rog sa imi dati cateva sfaturi. Difuzoare decente, la preturi decente.
Momentan ramane acest player. Stiu, este de ordinul "mediocru". In viitor, va si el inlocuit.
Sunt bine-venite orice fel de sugestii, idei. Chiar, va rog.
Va multumesc pentru timpul acordat!
In cazul in care acest topic este deschis in sectiunea unde nu isi are locul, va rog sa il mutati sau sa il stergeti.
Cateva poze:
AlexSmL 11-08-11 00:21
Re: VW Polo 6n2 - denees
Salut denees , arata excelent polo!Sincer chiar dau super bine jantele negre de tabla...odata ce ai lasat o pe burta.
In legatura cu sistemul audio eu te as sfatui sa nu renunti la subwoofer(mai ales daca nu ai nevoie se spatiul din portbagaj).Oricat ai lucra usile...nu vei acoperi si frecventele reproduse de subwoofer.
Ca sistem pe fata iti recomand sa asculti orice gama de la Helix.S ar putea sa iti placa;)
Bigu 11-08-11 08:35
Pariu? :)
@denees, ce inseamna pret decent pentru tine? ar fi mai usor sa ti se recomande ceva intr-un anumit buget.
AlexBanu 11-08-11 09:21
Salutare,
Vezi aici ce modificari am adus eu masinii tot un VW Polo 6n2, poate te ajuta cu ceva: https://forum.4tuning.ro/384-sistemul...brax-team.html
denees 20-08-11 00:04
7 Attachment(s)
Multumesc! De mult timp ma uit pe aceasta sectiune. Pas cu pas am urmarit lucrarea ta, Alex. Citind si vazand atat de multe, m-a facut curios faptul ca se poate auzi un bass curat, produs doar de mid-bass-i. Nu am avut ocazia sa ascult o astfel de masina, bine antifonata, cu sisteme profesionale dedicate SQ-ului.
Incerc sa fac ceva, prin practica si diverse sisteme, dar si cu ajutorul vostru, de care am mare nevoie.
Am achizitionat un MP3 Player JVC SH99R si difuzoare, pe moment, MB Quart RCC 116. Orice parere ma poate ajuta in a lua decizii. De aceea, va rog sa spuneti orice, in legatura cu muzica.
roli 20-08-11 00:13
la doar 50 de km de tine e o masina zic eu bine pregatita profesional pt SQ la arad, esti asteptat cu placere, eu zic ca merita depus efortul de a te deplasa sa o asculti.
