Piese E36
Vand piese E36 316i din 1996:
#finala stock in stare f buna-60RON #conducte racire radiator-65 RON ambele #DME, EWS si cip cheie-250 RON #Debitmetru-180 RON |
Re: Piese E36
#finala stock in stare buna-60RON #conducte racire radiator-60 RON ambele #DME, EWS si cip cheie-240 RON #Debitmetru-170 RON Tel 0741741186 |
Re: Piese E36
Pune o poza cu toba daca vrei...
Re: Piese E36
Pun diseara, numai sa nu uit...:)
Re: Piese E36
Re: Piese E36
Re: Piese E36
#finala stock in stare buna-60RON #conducte racire radiator-50 RON ambele #DME, EWS si cip cheie-200 RON #Debitmetru-150 RON Tel 0741741186 |
Re: Piese E36
#finala stock in stare buna-60RON #conducte racire radiator-40 RON ambele #DME, EWS si cip cheie-170 RON #Debitmetru-130 RON Tel 0741741186 |
Re: Piese E36
Dezmembrez motor de pe 316i din 1996, 170.000 km
Preturi in RON, negociabile. Instalatie electrica(cutie, cabluri, mufe)-30; Relee-20 Sensor arbore-40; Senzor ax cu came-40; Senzor temperatura lichid racire-20; Senzor detonatie-30; Furtune vacuum-10; Lant distributie(3000km)-100; Patine-80; Tensionator lant(3000km!)-130; Evacuare finala-60; Corp/clapeta acceleratie-20; Ambreiaj-50; Termostat-50; Furtune radiator (2)-40; Injectoare (4)-80; Rampa injectie/reg. presiune-50; Debitmetru-120; Fise inductie-40 toate 4 Bloc motor, chiulasa, pistoane etc-300 ron Sau toate la 500 RON Tel 0741741186 |
Re: Piese E36
Preturi in RON, negociabile. Instalatie electrica(cutie, cabluri, mufe)-30; Relee-20 Sensor arbore-40; Senzor ax cu came-40; Senzor temperatura lichid racire-20; Senzor detonatie-30; Furtune vacuum-10; Lant distributie(3000km)-100; Patine-30; Tensionator lant(3000km!)-130; Evacuare finala-50; Corp/clapeta acceleratie-20; Ambreiaj-50; Termostat-30; Furtune radiator (2)-40; Injectoare (4)-60; Rampa injectie/regulator presiune-30; Debitmetru-120; Fise inductie-30 toate 4 Bloc motor, chiulasa, pistoane etc-300 ron Sau toate la 500 RON Tel 0741741186 |
Re: Piese E36
valabil
Re: Piese E36
valabil
Re: Piese E36
uuuuppppp
Re: Piese E36
salut
mai ai toba finala? daca da imi poti spune daca merge sa o pun pe un e36 cu motor de 2.0 vanos?..si daca merge ...mai spunemi daca face galagie toba...caci as prefera sa nu faca galagie ca a mea face galagie grav:)(nu are site si e si sparta) ms |
Re: Piese E36
Toba nu merge pe 320. :sad:
| All times are GMT +2. The time now is 09:43. |
