-   Talcioc (https://forum.4tuning.ro/79-talcioc.html)
-   -   Router 3G Vodafone B970 ieftin (https://forum.4tuning.ro/79-talcioc/258403-router-3g-vodafone-b970-ieftin.html)
marianpan 12-05-11 20:52
Vand un router Huawei B970 ,de la Vodafone,in cutie ,nefolosit,nou cu 300 ron si inca unul doar cu cablu de incarcare,folosit cu 100 ron
Huawei B970 Specifications * Dimensions: (L/W/H): 155mm x 115mm x 28mm
* Weight: < 500g
* Compatible OS: Windows 2000, XP, Vista, 7 (should work on Linux)
* Operating Frequency: HSPA/UMTS 2100MHz, GSM/GPRS/EDGE 850/900/1800/1900 MHz
* Support PC voice (optional) and SMS services
* Support data statistics Speed: 7.2 Mbps downlink, 2Mbps uplink
* Ethernet: 4 Ports (RJ45) 10/100
* Telephony: 1 Port (RJ11) for attaching an analogue phone
* WiFi: 802.11g
* USB Port: Doubles as either power in router mode or connectivity to a PC/Notebook in modem mode
* Antenna: 1 SMA connector for attaching a 3G antenna
* Light Indicators: Power, WiFi, Signal Strength, Mode (GPRS/EDGE/3G/HSPA)
* OS only matters when using it as a modem
