Vand Car-PC
Vand Car-Pc format din: Laptop Asus eepc 701 sh cu incarcator de casa + masina
Monitor 7" sh cu touch-screen Antena GPS USB Monitor:Sort: 7" touch screen with VGA, with IR 7"Headrest Desktop LCD with Touch Panel with VGA 7 Inches headrest/desktop in-car TFT-LCD monitor with touch panel and VGA. The screen is blue when there is no signal. Display Size: 7.0 inches (16: 9 TFT-LCD) Chip: New Digital Panasonic CMOS Resolution: 800*480 RGB Visual Angle: 40(l), 30(u) Brightness: 400, Contrast: 200 AV Chromatic System: PAL/NTSC(auto switch) Working Power: DC11.5V-13V Working Current: 900mA Operation Temperature: -10-50 Celsius Input Port: Double-channel video input, one VGA input, one USB input, one power input Dimension(cm): 17.5(l)*12.9(w)*3.2(h) Net Weight: 2.9kg Color: Dark black or silver gray Laptop:Caracteristici: ProcesorIntel® Celeron® M Frecventa procesor:900 MHz Tip display: TFT Diagonala: 7 Memorie: 2Gb DDR2 Hard Disk:4 GB Tip Hard Disk: SSD Audio: High Definition Audio Cititor de carduri: Da Retea: 10/100Mbps Ethernet Wireless WiFi 802.11b/g Baterie: 4 celule, 5200 mAh Autonomie de lucru: Pana la 3 ore si 50 min Greutate: 0.92 kg Securitate: Kensington Lock Caracteristici speciale: Microfon si boxe integrate Dimensiuni (W x D x H): 225 x 164 x 21.5-35 Culoare: negru SoftSistem de operare: Micro XP (windows ) Pret:300 de euro sau schimb cu CID Astra H |
Re: Vand Car-PC
--------se vand si separat----------
| All times are GMT +2. The time now is 09:44. |
