Vand Araldit
Vand Araldit extrem de puternic..este adeziv epoxidic bicomponent .lipeste orice(otel cupru aluminiu aliaje marmura pietre plastic lemn chiar orice) ,foarte rezistent mai ales la sarcini foarte mari , rezista la peste 300kg /cm2 .nu are concurent ,fiind folosit mai ales in industria de aeronave
Pret 10 euro 30ml sigilat in tuburile lui originale cine este interesat sa lase 1 PM Notă moderator: Lasă date de contact! |
Re: Vand Araldit
cateva detalii pe cei care nu cred e cel mai puternic ;) sursa wiki
in the UK Aero Research Limited. (ARL) - hence the name; ARaLdite, produced this new synthetic resin adhesive for bonding metals, glass, porcelain, china and other materials. Araldite sets by the interaction of a resin with a hardener. Heat is not necessary although warming will reduce the curing time and improve the strength of the bond. After curing, the joint was claimed to be impervious to boiling water and all common organic solvents. It is available in a pack containing the resin and the hardner. Applications The use of Araldite in architecture to bond thin joints of pre-cast concrete units was pioneered by Ove Arup in Coventry cathedral and the Sydney Opera House.[2] At Coventry cathedral, Araldite was used to bond its columns and fins, while at Sydney Opera House, Araldite was used to bond the rib sections of the shells, since a traditional concrete joint would have slowed construction, as it would need 24 hours to cure before stressing.[3] Highmark Manufacturing uses Araldite in the manufacture of advanced ballistic protection body armour Schlösser Metallbau, a manufacturer of metal parts for railway carriages, uses Araldite 2015 to bond aluminium profiles of cab doorframes on the BR 423 Siemens Bombardier tram Fischer Composite Technology GmbH uses the Araldite RTM System to produce carbon composite side blades for the Audi R8. contact: 0747320118 sau PM |
Re: Vand Araldit
uppp :)
Re: Vand Araldit
2 seturi au plecat luna trecuta la Bacanutinu .... niste poze
Re: Vand Araldit
uppp pt 1 adeziv extreme de puternic si eficient !!
Re: Vand Araldit
uppppp
| All times are GMT +2. The time now is 23:17. |
