Caut din dezmbrari pt E12 E23 E24 E28 E32 volanta
Ma intereseaza volanata , placa de presiune , elctromotorul (poate fi si ars ) si eventual discul de ambreiaj... DOAR de pe motor M30 ( E12 , E23 , E24, E28 , E32)
Da-mi PM |
Re: Caut din dezmbrari pt E12 E23 E24 E28 E32 volanta
RECTIFIC FARA E32
Ma intereseaza volanta masa dubla de 240X27 .... Nu cumpar 240X33 S-a pus pe urmatoarele modele : http://bmwfans.info/parts/catalog/11221270286/ Date tehnice la : http://bmwfans.info/parts/catalog/E2...mass_flywheel/ Piesa nr 8 codul 11 22 1 270 286 |
Part Cross-reference
RealOEM.com Home Part 11221270286 (Flywheel) was found on the following vehicles: E12: Details on E12 E12 528i Sedan, USA E12 530i Sedan, USA E12 525 Sedan, Europe E12 528 Sedan, Europe E12 528i Sedan, Europe E12 535i Sedan, Europe E23: Details on E23 E23 733i Sedan, USA E23 728 Sedan, Europe E23 728i Sedan, Europe E23 728iS Sedan, Europe E23 730 Sedan, Europe E23 733i Sedan, Europe E23 735i Sedan, Europe E24: Details on E24 E24 630CSi Coupe, USA E24 633CSi Coupe, USA E24 628CSi Coupe, Europe E24 630CS Coupe, Europe E24 633CSi Coupe, Europe E24 635CSi Coupe, Europe E28: Details on E28 E28 525i Sedan, Europe E28 528i Sedan, Europe E9: Details on E9 E9 2800CS Coupe, USA E9 3.0CS Coupe, USA E9 2.5CS Coupe, Europe E9 2800CS Coupe, Europe E9 3.0CS Coupe, Europe E9 3.0CSi Coupe, Europe E9 3.0CSiL Coupe, Europe E9 3.0CSL Coupe, Europe |
Da. Ma intereseaza daca are FIX codul ala cu greutate si dimensiuniel specificate. 240x27 mm... Te sun.
VALABIL !!!
valabil
Vezi ca un anunt se ridica o data la 48 de ore .
parca ti am mai postat odata am kitu de ambreaj si electromotor dar volanta am din cea mai scurta normala...
Cum adica " scurta, normala" ?
| All times are GMT +2. The time now is 01:11. |
