-   Masini de serie (https://forum.4tuning.ro/219-masini-serie.html)
-   -   BMW 335i Coupe (https://forum.4tuning.ro/219-masini-serie/24983-bmw-335i-coupe.html)
icey_xx 09-10-06 22:07
BMW 335i Coupe
10 Attachment(s)
BMW 335i Coupe
Engine
Type: Twin-Turbo Inline-6
Displacement cu in (cc): 183 (3000)
Power bhp (kW) at RPM: 300(224) / n.a.
Torque lb-ft (Nm) at RPM: 300(407) / 1400-5000
Redline at RPM: 7000
Performance
Acceleration 0-60 mph s: 5.3
Top Speed mph (km/h): 150 (241) - electronically limited
The turbo engine for those who don't like turbo engines
Powered by a twin-turbocharged, intercooled 3.0-liter inline six loosely based on the engine currently found in the 3 Series, the 335i's engine is the first turbocharged gasoline BMW engine in decades. The turbo engine forgoes the aluminum-magnesium block found in the normally aspirated variants in lieu of an all-aluminum block. Direct injection, whereby the fuel is introduced into the combustion chambers rather than into the intake manifold, improves efficiency and performance by cooling the intake charge, allowing a high 10.2:1 compression ratio.
BMW pegs the 335i's 0-62-mph acceleration at 5.5 and 5.7 seconds for the manual and automatic, respectively, courtesy of the new turbo mill's 300 ********** at 5,800 rpm and 295 pound-feet of torque from 1,300-5,000 rpm.
articolul complet:
http://www.edmunds.com/insideline/do...ticleId=116129
Pentru cei care au rezerve in legatura cu sound-ul unui astfel de motor:
https://www.youtube.com/watch?v=naLcI...elated&search=
icey_xx 09-10-06 22:15
Re: BMW 335i Coupe
Si acum parerea mea,
Mie imi place foarte mult masina asta, dar mi s-a parut ca a crescut cam putin puterea cu turbo, din moment ce motorul de la care s-a pornit are vreo 270 de cai, dar am citit undeva, ca a fost facut in felul asta pentru a nu concura cu viitorul m3, si ca oricum se poate creste puterea acestui motor destul de mult cu ajutorul unu chip tuning, presiunea de supraalimentare fiind controlata de ECU.
In legatura cu faptul ca este primul motor turbo si cu injectie directa pe benzina de la BMW de mult timp (de vreo 20 de ani cred), eu nu tin la traditia asta si cred ca este bine ca au facut acest pas... parerea mea...
RoSonic 09-10-06 22:46
Re: BMW 335i Coupe
https://forum.4tuning.ro/18-masini-tunate/16158-bmw-seria-3-e92-coupe-info-poze.html
sau
https://forum.4tuning.ro/showthread.p...701#post313701
Topic inchis, pe viitor foloseste search inainte de topic nou!
