-   Discutii generale moto (https://forum.4tuning.ro/571-discutii-generale-moto.html)
-   -   Kawasaki Ninja ... Date tehice (https://forum.4tuning.ro/571-discutii-generale-moto/24529-kawasaki-ninja-date-tehice.html)
Baby_I 02-10-06 00:10
Are cineva Kawasaki Ninja ? Daca da, imi poate spune ceva pareri / impresii si nu in ultimul rand ceva date tehnice ... ;). Merci
TazzY 02-10-06 20:17
Re: Kawasaki Ninja ... Date tehice
Pai care Ninja ca sunt mai multe.. :)
Eu o sa imi iau in curand ZX6-R 2006 :D
Baby_I 03-10-06 00:41
mda ..se pare ca sunt pe dinafara :D ... Mi-a recomandat cineva sa imi iau o moto Ninja ... acum m-ai bagat in ceata :) .. As vrea ceva nu mai mare de 70 CP .... 600 motor sau .. ma rog, ce variante ar fi ?!
TazzY 03-10-06 17:10
http://www.kawasaki.it/Objects/w320h...400D245008.jpg
Model Year
2006 Describes the type of engine (2 or 4 stroke) the general layout of the cylinders (in-line 4, V-twin, parallel twin or single cylinder) and the type of cooling system (air or liquid).
Engine type
4-stroke, liquid-cooled In-Line Four The combined volume of each cylinder measured in cubic centimetres.
Displacement
636 cm³ Bore is the internal diameter of the cylinder. Stroke is the distance the piston travels from the bottom to the top of the cylinder. Both are measured in millimetres
Bore x stroke
68.0 x 43.8 mm The ratio between minimum and maximum volume of the cylinder between the cylinder head and the top of the piston.
Compression ratio
12.9:1 Describes the operation of the valves (DOHC, SOHC, OHV and intake reed valve) and the number of valves per cylinder.
Valve/Induction system
DOHC, 16 valves Describes the maximum power the engine produces without any forced air system.
Maximum power
95.5 kW {130 PS}/14,000 rpm Describes the maximum power the engine will produce with air being forced into the air box, effectively pressurising the system.
Maximum power with RAM Air
100 kW {136 PS}/ 14,000 rpm The amount of driving force the engine produces.
Maximum torque
70.5 N-m {7.2 kgf-m}/11,500 rpm Describes how the fuel/air mixture is fed into the cylinder.
Fuel supply/Carburettor
ø 38 mm x 4 (Keihin), twin injection Describes the type of system used to produce the high voltage required to make the spark plug operate.
Ignition
Digital Describes how the product is started.
Starting
Electric The type of transmission and the number of gears.
Transmission
6-speed, return Describes the frame construction and material.
Frame type
Perimeter, pressed aluminium Rake is the angle the steering is inclined from the vertical. Trail is the distance between an imaginary line drawn vertically through the wheel axle and an imaginary line drawn through the steering head. The distance between these two lines when they meet the floor is the trail. (perhaps it would be easier to use a diagram).
Rake/Trail
25°/106 mm Describes the type of suspension.
Suspension, front
41 mm inverted cartridge fork with rebound and compression damping, spring preload adjustability and top-out springs. Describes the type of suspension.
Suspension, rear
Bottom-Link Uni-Trak with gas-charged shock, spring preload adjustability and top-out spring, stepless compression damping, stepless rebound damping. Describes the amount of travel on the front suspension from uncompressed to fully compressed.
Wheel travel, front
120 mm Describes the amount of travel on the rear suspension from uncompressed to fully compressed.
Wheel travel, rear
135 mm Describes the size of the front tyre.
Tyre, front
120/65ZR17M/C (56W) Describes the size of the rear tyre.
Tyre, rear
180/55ZR17M/C (73W) Describes the number and size of discs, type of calipers and number of pistons in the calipers. Or the number and size of drums. Dependant on product line.
Brakes, front
Dual semi-floating 300 mm discs, dual radial-mount, opposed 4-piston, 4 pad calipers. Describes the number and size of discs, type of calipers and number of pistons in the calipers. Or the number and size of drums. Dependant on product line.
Brakes, rear
220 mm disc with single Single-bore pin-slide Describes the angle that the wheels are turned when the steering is on full lock.
Steering angle, left / right
27° / 27° Gives the dimensions of the vehicle at the longest, widest and highest points.
Dimensions (L x W x H)
2,065 x 715 x 1,110 mm The distance in mm between the front and rear axles.
Wheelbase
1,390 mm The distance from the floor to the highest part of the seat.
Seat height
820 mm Fuel capacity
17 litres The weight of the product without fuel, oil and coolant.
Dry weight
164 kg Automatic Headlights On (AHO) is an initiative introduced by the European Association of Motorcycle Manufacturers (ACEM) in 2003 in order to increase the conspicuity of motorcycles. All 2004 MY Kawasaki have AHO fitted and this system operates in the following way. The headlamps automatically switch on after the ignition has been switched on and the starter button has been released.
Yes Complies to EU emission limit
EURO 2
__________________________________________________ _______________
Imi pare rau dar nu prea ai nimic la 600cmc pana in 70 de cai... Doar enduro..
Trainer 03-10-06 17:29
E foarte periculos pentru un incepator un ZX6R:130 cp pe 164 de kg,riscurile de a avea un accident sunt foarte mari.Cumpara si tu la inceput un motor de 125cc.Cine te-a sfatuit sa iti iei Ninja nu avea mari tangente cu motociclismul . Daca vrei sa aflii mai multe detalii intreaba pe forumurile dedicate motociclismului: http://www.motociclism.ro/forum si http://www.sbz.ro/modules.php?name=Forums
Baby_I 03-10-06 20:23
Va multumesc mult pentru info. Dau un print la datele tehnice de la Ninja ...
CAt despre Trainer .. stiu, ai dreptate, dar daca tot bag niste bani as vrea sa ii bag pentru mai mult timp si de asta nu prea m-as incurca cu un motor mic ... Oricum sunt in cerecetari , poate pe vara viitoare sa imi iau unul asa ca am timp sa ma documentez. Iti multumesc oricum de sfat ;)
Trainer 03-10-06 21:34
Evident ca decizia finala iti apartine tie,noi nu putem da decat niste sfaturi, dar a cumpara direct un motor mare pentru al tine mai mult timp,e la fel cum ai zice ca prima ta masina dupa ce ai luat carnetul o sa fie Bmw M5 ca sa nu mai cheltui bani pe masini mai slabe.Dar e o mare diferenta:la o masina puternica ai sisteme electronice,ai airbaguri ai sanse de scapare daca faci o greseala,la motociclete asa puternice ca ZX6R prima greseala la viteza mare duce de cele mai multe ori la moarte.Daca te hotaresti sa iti cumperi ZX6R nu uita de un echipament adecvat si complet.Asta este site-ul importatorului oficial http://www.unitedmotors.ro/ ZX6R are un pret de 8427euro CIP si ai si datele tehnice tot acolo.
TazzY 04-10-06 00:50
Sunt deacord cu Trainer... Ia-ti 125.. Reflexele se formeaza mult mai bine pe un motor mic.. Cu ce te ajuta o investitie pentru lunga durata daca se intampla vreo chestie naspa...?
ABWdesign 19-12-06 08:11
baietii au dreptate!
n-as vrea sa vii pe la atelierul meu! am reparat multe zx-uri!de la zx4 la zx12!
sunt adevarate "pain in the ass"
Magos 23-01-07 10:46
...si zzr?? :-/
Sher 30-01-07 00:19
Eterna scuza...
bogdan_kwx 31-01-07 20:53
daca vrei am un amic cu un ZZr de 400 pe la 55 cp si buna la pret.daca te intereseaza o poti vedea oricind in bucuresti
athmane 31-05-07 18:01
Re: Kawasaki Ninja ... Date tehice NEED HELP!
cum pot gasi o diagrama de moment(cuplu) pt modelele zx6 si zx 10 (ultimele modele) ??
TazzY 01-06-07 08:19
Da un search pe google "zx6r dyno test" sau ceva de genu... Daca aveam timp iti cautam eu.
