amplificator mtx xtunder x702
Specifications
CEA RMS Power : 2x70W @ 4Ohm, 14,4 Volts CEA RMS Power : 2x105W @ 2Ohm, 14,4 Volts CEA RMS Power : 1x210W @ 4Ohm Bridged, 14,4 Volts X-over : High pass 12dB variable from 40 to 8kHz X-over : Low pass 24dB variable from 40 to 8kHz X-over : Band pass 12dB variable from 40 to 8kHz Minimum Impedance : 2Ohm stereo or 4Ohm bridged Frequency response : 20Hz - 20kHz ±1dB THD+N / 1W : <0,1% S/N ratio : 85dB Sensitivity : 0,2 to 5Volts Dimensions : 22,0x21,0x5,0cm Features - Class AB stereo amp dedicated to power speakers and/or subwoofers - Can be used in Tri-mode - Variable x-over for Low pass, High pass and Band pass - High level input - Low impedance protection - Thermal protection - Regulated PWM MOSFET power supply - Oversized number of Mosfet on the final stage and the power supply - New BTR connectors - 100% garanteed power according to CEA norms - All connectors on one side SE POATE VEDEA SI TESTA IN BUCURESTI PRET 290 RON TEL.0724901401 |
up
urgent!!!260 ron.
Re: amplificator mtx xtunder x702
Doar azi:220ron.Pret fix.
Oferta valabila pana la ora 20. |
hai sus.
220 ron |
te intereseaza ampu meu blaupunkt in 4 canale pt Mtx?
nu,multumesc.am nevoie de bani.
se poate inchide.
multumesc. |
| All times are GMT +2. The time now is 13:23. |
