2 bmw e36 la dezmembrat
PIESE DIN DEZMEMBRARI, LIVRARE PRIN CURIER CU PLATA RAMBURS.
ELEMENTE CAROSERIE( aripa fata, capota motor, capota portbagaj, haion, bara protectie fata – spate, portiere / usa, trager / panou fata, armatura bara / intaritura, lonjeron, contra aripa, stalp, prag, aparatoare noroi ;) ELEMENTE OPTICE( far, semnalizator, stop, geam portiera, geam usa, luneta, parbriz, oglinda, tripla ;) ELEMENTE/ANEXE MOTOR( turbosuflanta / turbina, alternator, electromotor, compresor clima, compresor aer conditionat, pompa servo directie, injector, pompa injectie, galerie admisie, galerie evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor, clapeta acceleratie ;) ELEMENTE DIRECTIE/SUSPENSIE/TREN RULARE( arc elicoidal, telescop, amortizor, caseta directie, pompa servo directie, conducta servo directie, brat roata, bara stabilizare, fuzeta, port- fuzeta, jug motor, punte fata, punte spate, suport motor ;) ELEMENTE RACIRE MOTOR/HABITACLU( radiator apa, radiator clima, radiator intercooler, termoflot, electroventilator apa, electroventilator aer conditionat, electroventilator clima, electroventilator habitaclu, compresor clima, vascocuplaj, bimetal, aeroterma ;) ELEMENTE SIGURANTA( airbag sofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta, pretensionare centura, plansa bord, capac airbag ;) ELEMENTE TRANSMISIE( cutie viteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara, timonerie, fuzeta ;) ELEMENTE FRANARE( etrier frana, disc frana, pompa servo frana, pompa vacum, modul abs, senzor abs ;) ELEMENTE ELECTRICE( calculator motor, instalatie motor, ansamblu stergator parbriz, ansamblu stergator luneta, panou comanda ac clima, macara geam, broasca usa, ceas de bord, contact pornire, debidmetru aer, bloc lumini ;). DETALII: id mess dezmembrari_99 nr tel 0761533456 sau 0765705819 |
Re: 2 bmw e36 la dezmembrat
salut.Maciulie schimbator ai ?
Re: 3 bmw e36 la dezmembrat
10 Attachment(s)
orice din dezmembrari...puneti intrebari..sau detalii la 0761533456 SAU ID MESS dezmembrari_99
salut da-mi un pm daca mai ai radioator si la ce pret. ms
salut. poti verifica starea sabotilor de la pisica verde de la care am scos discurile?
| All times are GMT +2. The time now is 04:11. |
