-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   VAND AMPLIFICATOR MTX RT602 (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/239011-vand-amplificator-mtx-rt602.html)
victorash00 09-02-11 14:53
Produsul dispune de garantie pana in luna Mai 2012 la unul dintre cele mai cunoscute magazine de profil.
CEA RMS Power : 2x 90W @ 2 Ohm, THD+N ≤1%
CEA RMS Power : 2x 60W @ 4 Ohm, THD+N ≤1%
CEA RMS Power : 1x 180W @ 4 Ohm, THD+N ≤1%
High pass x-over : 12dB/oct variable from 40 to 400Hz
Low pass x-over : 12dB/oct variable from 40 to 400Hz
Signal-to-Noise Ratio (1 watt) : > 80dB
THD+Noise (Distortion) (1 watt) : ≤ 1%
Frequency Response (±1dB) : 20Hz-30000Hz
Maximum Input Signal : 6V
Maximum Sensitivity : 100mV
Dimensions : 310 x 180 x 55mm
Features
- Full Aluminium Design
- High End Construction
- Variable Active Crossover
- High level inputs
- PWM Mosfet power supply
- Safe and Secure connection terminals
- This amp was designed to be used in stereo with loudspeakers like MTX THS and THX. Or mono with low to medium power subs like MTX RT and XT. It is also possible to use this amp in mixed mono operation (tri-mode). For Stereo and Mono operation the Active Crossover makes it easy to match it to the connected speakers or sub.
Link catre pagina producatorului: http://www.mtxaudio.eu/spip.php?article1249
PRET : 350 RON
pentru contact folositi PM sau o766 466 8o1
victorash00 11-02-11 15:58
Re: VAND AMPLIFICATOR MTX RT602
UP !!!
victorash00 13-02-11 20:54
UP !!!
Robert_V6 14-02-11 08:48
pentru cine o cumpara, am eu remote pt statia asta 50Ron:)
victorash00 15-02-11 15:13
UP !!!
victorash00 19-02-11 12:30
UP !!!
Rey91 20-02-11 18:12
combinatii faci ?
victorash00 20-02-11 18:14
DA ... schimb cu bani
Rey91 20-02-11 18:14
ce raspuns inteligent!
victorash00 20-02-11 18:15
era un raspuns de tip NU pozitiv ... te-am bagat in ceata ?
victorash00 04-03-11 10:12
TRECI SUS CA TE POCNESC !!
lucianlucian 04-03-11 17:30
te intereseaza subu meu blaupunkt nou si statia tot blaupunkt din threadull meu pe statia ta?
victorash00 09-03-11 10:34
nu .. ms
victorash00 11-03-11 09:01
SUS ??
victorash00 15-03-11 16:59
UP !!!
