-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Amplficator T1 300W Rms (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/238024-amplficator-t1-300w-rms.html)
mih21 04-02-11 23:52
Amplificator T1 T1Audio LS500.2:
• Maximum Output 600W
• 4 Ohm Max Power Output @ 0.07% T.H.D. 300W
• 4 Ohm Bridged Power Output @ 0.07% T.H.D. 600W x 1 ch
• 2 Ohm RMS Output @ 0.07% T.H.D. 100W x 2ch
• 4 Ohm RMs Output @ 0.035% T.H.D. 50W x 2ch
• Low Pass Filter (Variable) 30Hz - 500Hz
• High Pass Filter (Variable) 50Hz - 1KHz
• Frequency Response 15Hz - 40KHz
• Signal to Noise Ratio >95dB
• Stable into 2Ohms operation
• Bass Boost (Variable) 0dB to + 18dB
• Subsonic Filter (Variable) 10Hz - 100Hz
• Input Sensitivity 200mV - 6V
• Input Impedance 47K Ohms
• Operation Voltage (Negative Ground) DC 12V
• Speaker Impedance @ Stereo Driven 4 Ohms
• Fuse Rating 25A x 2
• Dimensions ( W x H x D ) mm 242 x 54 x 288 mm
Pret 250 Ron
Contact:
Yahoo: n.mihai21
0722 469 856
andrei_znp 21-02-11 09:38
Re: Amplficator T1 300W Rms
salut, schimbi cu un detector beltronics v940?
mih21 21-02-11 16:07
Nu..tot cu vreun amplificator. Sau bani. Ms de oferta
Chiar..la un beltronics am si eu nevoie de un cablu de alimentare ca are contactele intrerupte..ai idee pe unde as gasi?
andrei_znp 21-02-11 20:56
hmm..pe okazii poate ... am o statie eu uitete la anunt
mih21 22-02-11 11:46
Ooo..mersi mult, nu ma gandeam sa caut pe okazii sau net.
Te intrebam daca stii pe undeva prin oras, ca-s mai ieftine decat pe net :)
Mersi oricum
