Vand diferite piese BMW E36 E46 E21 E28 E30 (super pret)
Vand diferite piese BMW E36 E46 E21 E28 E30 (super pret) Ce piese scriu decat atata mai am per model. E36 am cele mai multe toate preturile sunt negociabile lichidare garaj cine ia mai multe reduceri mai mari PIESE E21 Cardan ambele bucati 30 ron/buc Cuitie viteze 4+1 80 ron Piese motot M10 1600 bobina 60 ron Alternator 80 ron Electromotor 80 ron Delcou Complet 80 ron kit ambreaj disk+placa 80 ron pompa apa 50 ron pompa ulei 50 ron senzori apa termostat 30 ron fete usi fata spate albastre 30 ron/buc Consola centrala 50 ron PIESE E28[/SIZE][/SIZE] Grup normal carcasa mare + planetare +suport caroserie+cardan spate 300 ron Caseta servodirectie 100ron pompa ambreaj 80 ron pompa frana+tulumba 80 ron Usi 80 ron/buc aripi 80 ron/buc tragar 80 ron capota 80ron haion 50 ron faruri 80 ron/buc stopuri 50 ron/buc grile fata 50ron bord/consola/calculaor/ceas/etc - pret negociabil luneta incalzire 80ron Alte piese interior...etc Piese motor M30 alternator 100 ron electromotor 150 ron pompa ala + vascocuplaj 100 ron delcou complet 100 ron calculator m30b28 50 ron diac 50 ron debitmetru m30b28 80 ron pistoane m30b28 (se pot pune pe m20b25) 150ron toate bobina 60 ron PIESE E30 pompa ABS 120 ron piese motor m40b18 bobina 60 ron fise+delcou 80 ron alternator 100 ron PIESE E46 Piese motor 1800 8v an 2000 Electromotor 150 ron Alternator 150 ron Pompa servo 150 ron PIESE E36 coupe Use dreapta 150 ron(fara macara) macara drepta + motor 100 ron macara stanga 40 ron (fara motor) tripla M dreapta 60 ron Pompa ABS 120 ron calculator abs 80 ron discuri spate plus etrieri 50ron/buc (foarte bune) planetara staga grup deschis 60 ron grup deschis 100 ron(carcasa are urechi rupte si fara senzor) tot felul de butoane bord, topedou,diferite suruburi consola crem 30 ron mocheta crem 40 ron pistoane+ biele 1,8is 30ron/buc radiator ac 120 ron compresor AC pt 6 pistoane 200 ron elcromotor pt 6 pistoane 140A 240 ron vascocuplaj 6 pistoane 60 ron bara spate 80 ron (fara armatura si fara bandouri) rulment spate 50 ron/buc etrieri frana de mana 60 ron/buc motor trapa electrica 100ron trapa electrica mecanism 150 ron pompa frana+tulumba 80 ron pompa ambreaj 80 ron admisie 1,8is normala 150 ron/buc clapete 1,8 60 ron plus vacumuri senzori motor 1,8is tel:0767140877 id:gruia_mondialul |
Re: Vand diferite piese BMW E36 E46 E21 E28 E30 (super pret)
capac culbutori 1,8 is 60ron
chiuloasa 1,8 is 200 ron
Ma intereseaza asa :
- sonda temperatura exterioara ( sonda aia din bara fata ) am un 318i cu obd 7 butoane . - presurile din spate din materiale textil - proiectorul din dreapta masinii cu tot cu suport . |
ce culoare ai mocheta (pt presuri) proiectoarele s-au dat |
Pai eu le aveam un gri spre negru asa , iar marginea lor este verde .
aveam ceva crem....
Nu este problema .. pune 1-2 poze cu ele si daca sunt ok iti dau adresa sa le trimiti .
sal.
un vas de expansiune pentru un 318 e46 ? merci. |
s-a dat planetara staga grup deschis 60 ron
s-au dat farurile de e36
s-a dat pompa frana+tulumba e28
s-a dat cutia de viteze e21
s-a dat rulment spate e36...
S-a mai adus un e36 320 din 1997 la dezmembrat |
| All times are GMT +2. The time now is 09:05. |
