VAND 2X spl dynamics xtr 380d4
se vand difurile din titlu
functional impecabile Specificatii tehnice: * Diametru 12 inch * Putere Maxima 1500 W * Putere Nominala (RMS) 750 W * Impedanta 2 x 4 ohmi * Raspuns Frecventa 20-100 Hz * Sensibilitate 87,2 dB/W/m * Excursie Difuzor Xmax 24mm * Magnet 160 Oz * Vas 48,8 litri * Chrome Backplate * Enhanced Voice Coil Cooling * Sasiu Aluminiu * Adincime Instalare 170 mm * Greutate 11,3 kg foarte putin folosite nerodate pretz : 800 ron NEG ym shokaliptiku tel 0742 090 285 |
Re: VAND 2X spl dynamics xtr 380d4
o mica greseala de tipar
revizuire :lol: SPL Dynamics XTR-380D4 Specifications Size 395mm ( 15" ) Power handling (RMS/Peak) 1000/2000 W Nominal impedance 2 x 4 Ohm Mounting depth 195 mm Mounting diameter 350 mm Magnet weight 200 oz Voice Coil diameter 76 mm ( 3 " ) Voice Coil Type/Material DVC / BASV Weight 14.4 kg Voice Coils connection series parallel Impedance 8 Ohm-2 Ohm Fs 33.6 Hz-33.2 Hz Vas 53.3 L-52.6 L Qts 0.467-0.607 Qes 0.545-0.709 Qms 3.256-4.221 Xmax (lin/peak)13/26 mm Re 3.8 Ohm-0.9 Ohm Mms 403 g BL 29.31 TM-14.05 TM SPL (1W/1m) 88.9 dB-88.7 dB |
valabil 2X 15 :lol:
800ron/bucata 1550ron ambele |
sus sus sus
1 s-a dat
2 rezervat pana maine !!! |
s-a dat si al IIlea
se poate inchide multumesc 4tuning |
| All times are GMT +2. The time now is 05:53. |
