-   Masini de serie (https://forum.4tuning.ro/219-masini-serie.html)
-   -   Skoda shows off Octavia Scout (https://forum.4tuning.ro/219-masini-serie/22762-skoda-shows-off-octavia-scout.html)
DyZ 30-08-06 21:44
No neckerchief or proficiency badge for first aid here, though. The Scout is a beefier semi-off-road version of the Octavia estate. Think Audi Allroad and you're on the right lines.
Sitting 40mm higher from the ground than a standard Octavia estate, the Scout is better able to deal with knotty tracks.
The car is based on the Octavia Combi 4x4, and four-wheel drive is standard, while 17in alloy wheels are shod with chunkier tyres.
You'll have no problem spotting an Octavia Scout, thanks to its larger protective bumpers, sills and the bash-plate for the engine's sump.
Look closely and you'll also see the word 'Scout' embossed into the front sills and polished twin exhaust pipes.
The Octavia's optional Jumbo Box is standard for the Scout model and there's a passenger handgrip on the dashboard for those extreme off-road ventures.
Powering things on the rough and smooth stuff are 2.0-litre petrol and turbodiesel engines.
The petrol is the 148bhp FSi unit, and the turbodiesel is the 138bhp 2.0-litre engine seen in other Octavia models. Both come with a six-speed manual gearbox.
The Octavia Scout makes it debut in that most extreme of environments, the Paris motor show, before going on sale in the UK at the start of 2007.
Spark 31-08-06 21:24
Re: Skoda shows off Octavia Scout
e chiar reusita si arata bine :)
asteptam sa o vedem si pe sosele
fuzzy 04-09-06 08:19
hmmm... chiar arata bine... imi place... sper sa aibe motorizari klumea fiindca designul chiar e frumusel :D
dexter_20 04-09-06 19:40
Oare sunt singurul caruia ii miroase a Cayenne la partea din spate?
Spark 04-09-06 19:46
cred ca da :D
19tdi 08-09-06 10:25
chiar seamana cu un cayenne....da nu e un adevarat off-road e genu la audi allroad...e octavia 2 combi marita garda cu vreo 40 mm in legatura cu motoare....skoda ofera un 2.0 tdi de 140CP si un 2.0 fsi de 150CP...
BLinKY 09-09-06 01:32
Pai arata intradevar bine, seamana cu a6 allroad perfect:D la scara mica, dar nu o sa aiba performante ca el. Sa speram ca o sa aiba vanzare, deoarece nu prea stiu daca o sa ii intereseze pe multi Skoda Octavia kombi "inaltata"
19tdi 09-09-06 16:05
yo cred ca o sa aiba succes p piata deoarece cum a demonstrat de mai multe ori skoda a scos modele bune la preturi foarte mici in comparatie cu modele asemanatoare dar de la alte uzine
TAZ_IS_04_JMG 10-09-06 09:37
o asteptam pe strada...
fuzzy 11-09-06 18:42
hmmm... oare spatele e de cayenne??? oare skoda si porsche apartin amandoua VW?!?? hmmmm....
Seby_16V 19-09-06 12:02
foarte reusita masina :) dak stau putin sa fac o comparatie "aberanta" as zice :de la Octavia sedan - la Octavia Scout .... si .... Logan sedan - la Logan Steppe (si nu ma refer la varianta prezentata la Geneva,ci la cea simpla) :| intrebare : de ce mama drq altii pot si noi nu ?????
Cosmin255 21-11-06 18:36
masinuta e chiar atractiva , pretul oare va unde bate?...cred ca pe la 20-22k cam asa nu?
kornuletz 23-11-06 15:15
ce pot sa zic...urata cu spume..urasc skoda...:oops:
19tdi 23-11-06 16:43
gusturile nu se discuta...mie imi place la nebunie....eu o gasesc ft reusita...si consumu ft mic pt un 4x4...8.7 pentru 2.0 fsi de 150 cp...si doar 6.4 pt 2.0 tdi de 140 cp.....:shock:
Todorutz 24-11-06 12:29
intr-adevar aduce mult a audi allroad mai ales din cauza kit-ului acela exterior, dar nu ma mira acest fapt k doar sunt din aceeasi clasa :)....oricum foarte tare masina. imi place k in ultimu timp skoda a scos modele diverse intrand pe mai multe segmente de piatza...un alt exemplu ar fi roomster care deja a fost lansat si cred k se bucura de un succes...
