Vand amplicator sau schimb cu boxe de 16 cm
Vand statie blaupunkt Gta 450 4/3/2 canale sau schimb cu boxe de 16 cm
Max. power (4 ohms) 640 W (2-channel mode) 4 ohmi, stereo: 4 x 55W RMS (4 x 110W max) 4 ohmi, bridge: 2 x 180W RMS (2 x 360W max) Bridging mode - channels 4/3/2 Speaker outputs 4 Preamp-in Cinch/RCA gold-plated Response 10-30.000 Hz Stability 2 ohms S/N ratio > 90 dB/A Gain adjust 0,1-8 V Low-pass 40-450 Hz variable High-pass 65-450 Hz variable Bass Boost 0/9/18 dB switchable + Particularities Casing: brushed aluminium / graphite gray tel 0745514218 id robert_88rob pret 210 Ron |
Re: Vand amplicator sau schimb cu boxe de 16 cm
Up.....
Up.....
Up....
Up.....
Re: Vand amplificator sau schimb cu boxe de 16 cm
sus cu amplificatoru..
Up.....
Up......
Up....
Up....
salut. am doua boxe ovale magnat 6/9 pe trei cai 75rms cu grila daca te intereseaza pm sau 0754018929
schimbi cu un amplificator jbl gto 75.2 ?
Up....
ofer 150ron, bucuresti
| All times are GMT +2. The time now is 19:00. |
