sistem audio
1. vand Amplificator full range JBL CS 60.2, pe 2 canale 2x60 W pentru masina.
Putere RMS 120 W Frecventa de raspuns 10Hz - 27kHz (-3dB) Raport semnal/zgomot (referinta 1 watt la 4 ohms) 86 dBA Impedanta Iesire 2 sau 4 ohmi Dimensiuni (HxWxD) 225 x 260 x 57 mm Altele 4 ohmi: 2 x 60 W RMS 2 ohmi: 2 x 80 W RMS 4 ohmi, in punte: 1 x 160 W RMS Bass boost variabil 0-6 dB la 45 Hz Nivel semnal intrare 100mV - 6 V Amplificator auto 2 canale MOSFET. 2. AMPLIFICATOR AUTO 4 CANALE JBL CS60.4 * amplificator pe 4 canale, clasa AB * putere maxima: 400W * putere RMS @ 4 Ohm: 4 x 60W * putere RMS @ 2 Ohm: 4 x 75W * putere RMS in punte @ 4 ohm: 2 x 150W * raspuns in frecventa: 10Hz – 30kHz * THD: 0,10% * raport semnal/zgomot: >100dBA * crossover: Flat / LP / HP, variabil 30 – 320Hz (12dB / oct.) * iesire preamp 2 canale * dimensiuni (H x W x D): 384x313x60mm. 3. subwoofer jbl de 400w real 4. condensator 1 Farad 21 VDC voltmetru digital cu LCD activare cu telecomanda 5. filtre + cabluri cu capete auri pret total 1000 ron |
Re: sistem audio
Re: sistem audio
Pret condensator separat?
JBL-ul CS 60.2? Sau amandoua impreuna...eventual... |
Re: sistem audio
300 ron |
Re: sistem audio
upp upp
| All times are GMT +2. The time now is 03:33. |
