[VAND] SOFT M50
-doar pt motoarele M50
PEAK HORSEPOWER +26 HP PEAK TORQUE +22 LBS/FT REV LIMITER +400 RPM Performance Chip unleashes more power by re-programming the fuel mixture and ignition timing parameters of the engine management system. Furthermore, the software safely raises the rev-limit, giving your BMW a broader power band and greater road speed potential in each gear. Significant gains are also achieved at part throttle, making extra power available where you spend the bulk of the time driving. The top speed governor has also been eliminated, enabling the vehicle to achieve it's "natural" top speed. PRET: 3 mil TEL: 0761 335 155 |
Re: VAND SOFT M50
upppppppppp
Re: VAND SOFT M50
uppppppppppp
Re: VAND SOFT M50
upppppppppppppp
Re: VAND SOFT M50
50 E upppppppppppppp
Re: VAND SOFT M50
ce adaugari se fac.. filtru sport toba, CAI.. pentru soft ? sau doar il bag in ecu...? si pt ce ecu e?
Re: VAND SOFT M50
Adjudecat, azi am vb cu omu ce si cum.
Re: VAND SOFT M50
Revine la vanzare, softul se poate monta doar pe ECU 405
Re: VAND SOFT M50
upppp....am si ECU 405 cine doreste....
| All times are GMT +2. The time now is 10:28. |
