-   -   New Mazda 3 MPS Hot Hatch (https://forum.4tuning.ro/18-masini-tunate/22331-new-mazda-3-mps-hot-hatch.html)
BogdanNZ 22-08-06 14:56
7 Attachment(s)
Am considerat ca aparitia acestei masini in Austral-Asia in urmatoarele luni si in restul lumii in 2007 e destul de semnificativa pt a avea un thread al ei.
Mazda 3 MPS specs.
Engine
Engine type 2.3 litre Direct Injection Spark Ignition (DISI) turbocharged intercooled in-line 4 cylinder 16 valve DOHC
Engine capacity cc 2,260
Bore and stroke mm 87.5 x 94.0
Compression ratio 9.5 : 1
Maximum power kW 190 @ 5,500rpm
Maximum torque Nm 380 @ 3,000rpm
Throttle control Electronic (drive-by-wire)
Fuel system Direct multipoint electronic injection
Fuel tank capacity litres 55
Fuel consumption combined 1 l/100km 10.0
Recommended fuel Premium unleaded (min. 95RON)
Transmission Ratios
1st 3.538
2nd 2.238
3rd 1.535
4th 1.171
5th 1.085
6th 0.853
Reverse 3.831
Final drive 3.941 (1st-4th) 3.350 (5th-6th)
Brake type front Ventilated disc
rear Solid disc
Brake diameter front mm 320
rear mm 280
Suspension front Independent MacPherson strut with coil springs and double acting shock absorbers
rear Independent multi-link with low profile springs and cylindrical double acting shock absorbers
Steering Hydraulic power assisted (engine revolution sensing) rack and pinion
Turning circle kerb to kerb m 11.0
Tyres 215/45R18 89W
Wheels 18 x 7.0 J (alloy)
Spare tyre/wheel Temporary
Overall length mm 4,430
Overall width mm 1,765
Overall height mm 1,465
Wheelbase mm 2,640
Ground clearance laden mm 121
Track front mm 1,535 rear mm 1,525
Cargo room volume litres 290
Kerb weight kg 1,403
Dotari standard:
jenti pe 18", power mirrors, power windows, full aero body kit + roof spoiler, finala cromata, folie verzuie pe toate geamurile, faruri Xenon(optional), faruri ceatza, stopuri led clare, climatizare, cruise control,sistem audio Bose (Mp-3, 6 boxe si subwoofer optional), control audio pe volan, volan si cap schimbator din piele,scaune recaro(piele optional), ABS, EBD, EBA, DSC(dynamic stability control), TSC(traction control), LSD (limited slip diff!!!), 6 airbags, remote central locking, immobiliser etc etc. lista poate continua pana maine...
Pretul in Australia/NZ este de AUS$39900 fara taxe de drum.In europa asta ar cam insemna 23600Euro(plus taxele de rigoare...)
Ce parere aveti despre masinutza asta gata tunarita(relativ) din fabrica.Cred ca cel mai mult ma impresioneaza cifrele de 190KW~aproape 260 cai!!! si 0-100 in 6.1s, de la o masina care poate fi si practica la o adica, retineti ca e hatch in 5 usi.
Restul de dotari nu sunt cine stie ce avand in vedere ca vb de o firma japoneza.
dreamer 22-08-06 15:17
Re: New Mazda 3 MPS Hot Hatch
Frumoasa masina,performante f bune,mai ramane sa vedem pretul...daca este si mai ieftina ca GTI,nu inteleg dc nu am alege asta...Dar gti e gti...
neXus 22-08-06 20:25
Fain Fain. Foarte fain :)
Ce pot spune? Mi-ar placea si mie asta. Dar chiar sa fie mai rapida decat un GTI sau Megane RS? Nu cred...
teddy 23-08-06 02:32
GTI are istorie dar mai nou are si multi adversari care il lasa in urma... "GTI e GTI" e o afirmatie care ar fi stupid sa te influenteze cand iti alegi masina...
Bmw_Rulllzzz 23-08-06 02:48
am observat k tare iti place sa intri in polemica teddy (no offence)
dreamer 23-08-06 02:48
Dar totusi VW e marca pe langa Mazda...si totusi netinand cont de asta te uiti la pret,performante si...vezi realu'
teddy 23-08-06 02:58
Bmw_Rulllzzz, am pareri bine definite si mi le apar cu argumente, ceea ce multi nu fac. oricum, asta este rostul unui 'forum' - discutam, comentam, ne dam cu parerea, polemizam.
si atat timp cat facem toate astea in limita decentei - E TOTUL IN REGULA!
Bmw_Rulllzzz 23-08-06 03:13
nu prea imi place sa recunosc dar ai dreptate de data asta (cu sensul forum-ului) :D:D:D:D:D:D
alexSHO 24-08-06 22:40
amigo,,, pret de GTI ? R32 nu-ti mai place? desi cred ca o sa fie mai scumpa cu toate taxele platite
Race 30-08-06 21:35
Nu e ciudat cum majoritatea concurentei poate folosi cutii normale pe hot-hatch-uri,iar Mazda are nevoie de una cu 3 axe la fel ca pe 6 MPS ?
E de apreciat totusi LSD-ul.
