Porsche 997 Turbo Vs Lamborghini Gallardo Vs Sl 55 Amg
8 Attachment(s)
Porsche 997 Turbo Vs Gallardo Vs Sl 55 Amg
Re: Porsche 997 Turbo Vs Lamborghini Gallardo Vs Sl 55 Amg
SL 55 AMG engine AMG Supercharged V8
position Front Longitudinal valvetrain SOHC w/3 Valves per Cyl displacement 5439 cc / 331.9 cu in bore 97 mm / 3.82 in stroke 92 mm / 3.62 in compression 9.0:1 power 355.0 kw / 476.1 bhp @ 6100 rpm hp per litre 87.53 bhp per litre bhp/weight torque 700 nm / 516.3 ft lbs @ 6250-4500 rpm drive wheels Front Engine / RWD body / frame Unit Steel front brakes Internally Vented Discs w/ABS, Power Assist & SBC f brake size 334 mm / 13.1 in rear brakes Internally Vented Discs w/ABS, Power Assist & SBC r brake size 300 mm / 11.8 in front wheels F 45.7 x 21.6 cm / 18.0 x 8.5 in rear wheels R 45.7 x 24.1 cm / 18.0 x 9.5 in front tire size 245/40ZR18 rear tire size 275/35 ZR 18 steering Rack & Pinoin w/ f suspension 4-Link Strut Suspension w/Coil Springs, Shock Absorber, Stabiliz r suspension Multi-Link w/Coil Springs, Shock Absorber, Stabilizer weight 1820 kg / 4012 lbs wheelbase 2515 mm / 99.0 in front track 1553 mm / 61.1 in rear track 1545 mm / 60.8 in length 4499 mm / 177.1 in width 1812 mm / 71.3 in height 1275 mm / 50.2 in transmission 5-Speed Auto gear ratios 3.59:1, 2.19:1, 1.41:1, 1.00:1, 0.83:1 final drive 2.82:1 top speed 250 kph / 155.3 mph 0 - 60 mph 4.6 seconds |
LAMBORGHINI GALLARDO engine 90 Degree, Aluminum V10.
position Mid Longitudinal aspiration Natural valvetrain DOHC, 4 Valves per Cyl w/Variable Intake System & Continuously Varibale Valve Timing fuel feed Multipoint Sequential Fuel Injection displacement 4961 cc / 302.7 cu in bore 82.5 mm / 3.25 in stroke 92.8 mm / 3.65 in compression 11.0:1 power 372.9 kw / 500 bhp @ 7800 rpm hp per litre 100.79 bhp per litre bhp/weight 340.14 bhp per weight torque 510 nm / 376.2 ft lbs @ 4500 rpm redline 8100 drive wheels 4WD w/Viscous Traction System body / frame Aluminum & Thermoplastic over Aluminum Spaceframe front brakes Vented Discs w/Brembro 8-Piston Calipers, ABS f brake size 365 mm / 14.4 in rear brakes Vented Discs w/Brembro 8-Piston Calipers, ABS r brake size 335 mm / 13.2 in front wheels F 48.3 x 21.6 cm / 19 x 8.5 in rear wheels R 48.3 x 27.9 cm / 19 x 11 in front tire size Pirelli Pzero 235/35 ZR 19 rear tire size Pirelli Pzero 295/30 ZR 19 steering Rack & Pinion w/Power Assist f suspension Double Wishbones w/Anti-Roll Bar r suspension Double Wishbones w/Anti-Roll Bar weight 1470 kg / 3241 lbs wheelbase 2560 mm / 100.8 in front track 1622 mm / 63.9 in rear track 1592 mm / 62.7 in length 4300 mm / 169.3 in width 1900 mm / 74.8 in height 1165 mm / 45.9 in transmission 6-Speed Manual w/Optional Robotized E-Gear gear ratios 2.563:1, 1.850:1, 1.423:1, 1.138:1, 0.939:1 final drive 3.077:1 top speed 309 kph / 192.0 mph 0 - 60 mph 4.1 seconds 0 - 100 mph 9.0 seconds |
PORSCHE 997 TURBO aspiration Twin Turbos
valvetrain DOHC, 4 Valves per Cyl fuel feed Bosch Motronic DME 7.8 Fuel injection displacement 3600 cc / 219.7 cu in bore 100 mm / 3.94 in stroke 76.4 mm / 3.01 in compression 9.4:1 power 357.9 kw / 480 bhp @ 6000 rpm hp per litre 133.33 bhp per litre torque 620 nm / 457.3 ft lbs @ 1950 rpm drive wheels AWD body / frame Unit Steel front brakes Vented Discs rear brakes Vented Discs steering Rack & Pinion f suspension MacPherson Struts r suspension Mulit-Link transmission 6-Speed Manual top speed 310.6 kph / 193 mph |
poti sa inchizi acest topic, se stie deja cine este castigatorul :)
porsche :)
depinde care este criteriul de departajare.....
Daca privesti dpdv al performantelor Porschele este cu o clasa peste Lambo si cu 3 clase peste Sl Daca vrei sa se uite lumea pe strada dupa tine iti iei Lambo Daca esti Irinel iti iei Sl55 Amg |
Porsche, fratilor... Gallardo nu are nici manevrabilitatea si nici capacitatea de a fi tunat a unui Porsche 997, nici confortul lui SL55AMG... doar faima de Lamborghini, dar uneori aia e mai importanta decat orice ;)
~Nautilus |
asa e...lamborghini...suna a masina exotica...faima..dar cand zici lambo parerea mea k te gandesti tot la diablo..nu stiu dc..dar ala e adevaratul lambo ....
Mie nu mi-a placut Diablo niciodata - prea patratzos, urat, cu spatiu interior mic.. si, dupa parerea celor care l-au testat, franele si suspensiile nu faceau fatza puterii enorme, de aproape 500 CP. Predecesorul lui, Countach, era extraordinar. Lambo-ul perfect, dupa mine, era proiectul Cala, din nefericire VAG au decis sa-l dea la naftalina si sa construiasca Gallardo in loc
~Nautilus |
Acuma nici sa nu exageram in ceea ce priveste Lambo-ul.....
Uite un exemplu de om care a avut Gallardo l-a vandut si si-a cumparat 997 Turbo iar acuma ii pare rau http://www.6speedonline.com/forums/s...ad.php?t=53676 Cine spune ca de Gallardo nu e decat firma nu cunoaste masina....... |
PS: Pentru cine nu a mai intrat pe http://www.6speedonline.com/forums
sa intre sa vada ..... Aproape toti userii de pe forum au masina despre care comenteaza......nu ca noi ... ne dam cu parerea despre toate, pretindem ca le stim pe toate dar nici un am vazut pe viu masina despre care vorbim |
sl 55 amg :) imi plac mashinile cabrio :)
Si de ce comparam cu Gallardo si nu cu Murcielago?
murcielago se compara cu porche carrera gt, cu mclaren slr..
| All times are GMT +2. The time now is 16:55. |
