Re: Jonway Sport Edition 50
Pana la urma Jonway asta e ceva chinezarie nu?!
Este chinezesc da , toata lumea zice ca sunt proaste dar al meu nu a avut nimic ... motorul fiind identic cu cel de honda . Am vazut ca cei din Japonia schimba motorul honda cu cel GY6 . Pun si cateva poze cu inculpatul Honda Zoomer .
GY6 Engine This is a 4 stroke single cylinder, air or oil cooled design that comes standard with two overhead valves. Stock horsepower ratings can be found quoted in the range of 7.8hp to 12.4hp. The engine is capable of producing 12,000 rpm and power upwards of 14 horespower with modifications according to end users. The gy6 engine has a built in swing arm with automatic CVT transmission that is belt driven. This engine was originally manufactured in 50cc, 125cc, and 150cc engine sizes and was found in the Honda Elite and Spacey line of motor scooters. Honda no longer uses this design on their scooters, but chinese, korean, and taiwanese copies of this engine are readily available. Current brands of of import scooter lines that use the Honda GY6 cloned engine technology include: Tank, Strada, Vento, Yamati, SUNL, and Roketa among others. With the wide availability and cheap cost of this engine, asian ATV manufacturers have started to use this powerplant in their youth line of ATVs (quads) and buggies (off road go karts and trail buggies) 150cc youth quads that contain the GY6 powerplant are found being imported under many brands including Yamoto, Kazuma, and Redcat. Off road buggies and full suspension go karts that include this style of engine inlclude Carter Brothers Talon Line, Carter Brothers XTV, TJ Powersports Twister Hammerhead, Dazon Raider, Kasea Adventure Buggy, Blade Powersports 150cc, Tomberlin Punisher & Crossfire, Baja Motorsports Dune 150. With the wide availability of this engine in both older Honda products and newer Asian imports there is a vast amount of information, modifications, and performance parts available to the end user. User forums such as buggy news go karts and off road buggy forum and scootdawg forumoffer end users an excellent place to discuss and troublshoot these engines. Users on these forums have tried a variety of modifications produced by third party vendors such as 4 valved high compression heads, big bore kits, high peformance CVTs, performance CDIs, performance carburetors, and performance exhaust kits. The forums are also an excellent source of engine service manuals and general repair guides for tune up and major repair information |
Acum ma gandesc sa iau un set de lupe pentru faruri . si-a pus cineva ?
SE VINDE TRANSMISIA STOCK !!! PENTRU INCERCAT DIVERSE CONFIGURATII ROLE/ARCULETE
VAND KIT TRANSMISIE SCUTER GY6 4T , AMBREIAJ - STOCK , ARCULETE + ARC CENTRAL STOCK / VARIATOR - STOCK + ROLE DE 5,5 GR . PRET NEGOCIABIL (PM) , MOTIVUL VANZARII : AM SCHIMBAT PENTRU UN ALT RAPORT AL TRANSMISIEI . |
Scuterul a primit revizia 10.000 km - schimbat filtrul de aer
- schimbat filtru de benzina - schimbat bujie (NGK - cod : A7RTC ) - schimbat uleiul din transmisie-grup ( Malossi ) - schimbat uleiul din motor ( Motul ) - schimbat rulmentii fata ( SKF 6201 2RZ ) TRANSMISIA INCA ESTE DE VANZARE !!! |
Diametrul variaza sunt mai multe modele ... la fel si adancimea lupei intre 6-7 cm . Ad georgealexandru939 .
Astazi au ajuns ornamentele-lupa custom pentru pozitii urmeaza sa fie facute fumurii si montate .
Mici ajustari ... bobina de inductie directa NCY PERFORMANCE + Fisa si pipa NGK .
O sa iau ... am facut lupe mate pentru pozitii le-am montat si cam atat , am vrut sa-l fac cum mi-am dorit pe partea de mecanica in principal ... estetica poate astepta :) dar asta urmeaza acum am terminat cu reglajele si o sa-l desfac sa-i dau un polish mai detaliat sa-i strang firele ce stau in dezordine ... si cam atat :) Bafta tuturor .
Gen stikere sa fie ... imi place mult stilul asta :) la noi oare zic ceva politistii ?
Personalizat in propriul stil.
Cand te apuci de lipit :))? |
