-   Piese BMW de vanzare (https://forum.4tuning.ro/641-piese-bmw-vanzare.html)
-   -   Piese Diverse E36 - take a look (https://forum.4tuning.ro/641-piese-bmw-vanzare/217316-piese-diverse-e36-take-look.html)
cobrelu 29-10-10 08:46
11 Attachment(s)
Vand urmatoarele piese pentru BMW E36 provenite de pe 318IS - motor M42:
-Vascocuplaj BEHR (fan coupling) - COD 11521740962OEM BMW stare impecabila, perfect functional, fara nici o scurgere de ulei (schimbat pentru ca s-a trecut pe electroventilator) compatibil cu E28,E30,E34,E36,E39,Z1,Z3 ===100 lei
-Paleta/Elice Racire (fan blade) COD 11521723363 (compatibil E24,E28,E30,E34,E36,E39,Z1,Z3) stare impecabila, nici o urma de deteriorare == 40 lei
-Maneta Stergatoare (wiper switch) E36 COD 61311393310 === 35 lei
-Termostat Circuit Racire COD 11537511083 - 92 grade celsius rulat pe masina in jur de 3000km
compatibil cu motoarele pe benzina de la modelele E34 (520,525) E36 (316,318,320,323,325,328) E38 (728) E39 (520,523,528) Z3 (2.8) === 60 lei
-Robinet Incalzire Apa (water valve) BOSCH COD 64118375792 pentru modelele cu AC dublu compatibil modele E36 (316,318,320,323,325,328,M3) === 90 lei
-Sonda Temperatura (mufa neagra) COD 12621747281 OEM ELBI (130 grade max) - perfect functionala compatibila cu E23 (735) E24 (635) E28 (518,520,535) E30 (316,318,320,323,325,M3) E32 (730,735) E34 (518,520,525,535,M5) E36 (316,318,320,325) Z1 === 30 lei
-Senzor Temperatura (mufa albastra) COD 13621709966 OEM Siemens VDO (140 grade max) - perfect functional compatibila cu E23 (735) E24 (635) E28 (518,520,535) E30 (316,318,320,323,325,M3) E32 (730,735) E34 (518,520,525,535,M5) E36 (316,318,320,325) Z1 === 30 lei
-Termocontact (double temperature switch) 91/99 grade celsius pentru radiator cu ventilator auxiliar COD 61311378073 OEM BMW perfect functional compatibil cu E24 (635) E30 (316,318,320,324TD,325,M3) E31 (840,850) E32(730,735,740,750) E34(518,520,524TD,525,530,535,M5) E36 (316,318,320,323,325,328,M3) Z3 (1.8,1.9,2.8) === 60 lei
-Flaps Aer stanga spate (trim panel left) COD 51718130071 http://www.realoem.com/bmw/partxref....071&showeur=on === 20 lei
-Izolatie Termica Capota Coupe / Insonorizare Capota (sound insulating engine hood) COD 51481977128 in starea in care se vede in poza, nu este rupta === 50 lei
-Tunel Aer Radiator / Difuzor Aer (fan shroud) COD 17111723066 in starea in care se vede in poza, ii lipseste o ureche de sus insa merge prins cu banda clips de unica folosinta (soricei) === 40 lei
-Rola Intinzatoare (adjusting pulley): 8 bucati COD 11281748131 OEM INA - au foarte mic joc insa rulmentul se invarte bine si fara huruit === 25 lei
PRETURI NEGOCIABILE
hdc77ro 29-10-10 16:09
Re: Piese Diverse E36 - take a look
salut
water valvele in ce stare e? ai idee? sa nu clampane ca e pe moarte? daca e bun sunt interesat. multumesc
cobrelu 29-10-10 20:17
este in stare buna..o testam pe masina, ii bagam mufa si vedem cum inchide si deschide complet. Eu nu am auzit nici un sunet la ea.
cobrelu 09-11-10 10:09
Vascocuplajul si Elicea nu mai sunt ...pentru restul UP
cobrelu 12-12-10 15:21
s-a dus si termostatul - la un 520i Pentru restul, UP
