-   Talcioc (https://forum.4tuning.ro/79-talcioc.html)
-   -   Vand placa de baza ECS M952 (https://forum.4tuning.ro/79-talcioc/212703-vand-placa-baza-ecs-m952.html)
Spot 06-10-10 14:02
Placa Elitegroup Computer Systems cu rumatoarele specificatii:
CPU
Socket 478 for Intel Pentium 4 processor
FSB
800/533/400 MHz
Chipset
VIA PT800/8237
Memory
2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266)
Maximum: 2GB
Expansion Slots
1 x AGP 8X
4 x PCI
1 x CNR slot
LAN
VIA VT6103 10/100Mbps Fast Ethernet PHY
Audio
C-Media CMI9761 6-channel audio Codec
Compliant with AC97 2.2 specification
IDE
2 x UltraDMA 133/100/66
Back Panel I/O Ports
1 x PS/2 keyboard
1 x PS/2 mouse
1 x Parallel Port
1 x Serial Port
4 x USB 2.0 Ports
1 x RJ 45 Port
1 x Audio I/O (Line-in, Line-out and Mic-in)
Internal I/O Connectors & Headers
20-pin ATX power supply connector
4-pin ATX 12V power supply connector
1 x Floppy connector-support 360K~2.88M Byte, 3 Mode FDDs or LS120
1 x IrDA for SIR header
1 x CD in header
1 x Speaker header
2 x USB 2.0 header support additional 4 USB2.0 ports
1 x Front panel switch/LED header
2 x Serial ATA connectors
CPU / SYS FAN headers
1 x USB card reader header
1 x Front panel audio header
System BIOS
AMI 2Mb Flash ROM
Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
Full support for ACPI revision 1.0 specification
Form Factor
ATX Form Factor, 305*190mm
Placa de baza vine insotita cu un procesor Intel P4 Prescott 2,4 Ghz +coolerul aferent.
Pret: 150 Ron negociabil
Contact: Cristi (socului_gangstarr) sau 0765168624
Spot 08-10-10 14:55
Re: Vand placa de baza ECS M952
am uitat sa precizez un aspect important,sloturile pentru mouse si tastatura nu sunt functionale...placa este in continuare de vanzare,la un pret negociabil.
Spot 22-10-10 14:50
up..negociabil!
Spot 16-11-10 14:34
up.!.....
Spot 22-11-10 22:11
valabil.....
Spot 30-12-10 14:48
s-a dat! se poate inchide topicul.
