VAND JBL LC-1504 Impecabil
Vand statie jbl lc-a504 ,impecabila. estetic 10/10, tehnic 10/10.
High-Speed Switching Power Supply , High-Current MOSFET Output Circuit , Continuously Variable Electronic Crossover , 4-Volt Head-Unit Compatible , Gold-Plated Power, Speaker and Input Connectors , Stable into 2 Ohms , Maximum Power Output: 125W x 2 , Power Output, 4 Ohms: 50W x 4 , Frequency Response: 20Hz-40kHz *Total Harmonic Distortion: 0.1% , Signal-to-Noise Ratio:>90 dB. Schimbi cu ceva monobloc sau cu intrare High low, o dau pentru ca la masina nu am iesire de rca si am nevoie de un amp pe maxim 2 canale cu intrare High low direct dupa boxe. 0723373907 Bucuresti 350 ron negociabil |
Re: VAND JBL LC-1504 Impecabil
uppppp
Sal! Nu prea ma pricep.. zi-mi si mie te rog daca am 4 difuzoare (2 fata + 2 spate) ce putere scoate conectat la ele? 50W? Si daca il conectez doar la 2 dif din fata scoate 120w?
scoate 50 w rms pe canal.
daca faci punte la subwoofer de 4 ohm scoate 125 w pe subwoofer apoi pe boxe cate 50. de obicei legi boxe spate le dai 50 w rms apoi legi pe celelalte 2 canale subwooferu in punte si ii dai 125 w rms. cum vrei. |
upppppp
uppppppp
upppppppp
| All times are GMT +2. The time now is 10:50. |
