-   Subwoofere auto (https://forum.4tuning.ro/553-subwoofere-auto.html)
-   -   VAND orice subwoofer SPL DYNAMICS (https://forum.4tuning.ro/553-subwoofere-auto/211001-vand-subwoofer-spl-dynamics.html)
Shokaliptiku 27-09-10 12:01
~~ Vand toata gama de subwoofere Spl Dynamics !!! ~~
Toate subwooferele sunt NOI
Ofer garantie
Se poate oferi "sprijin" in constructia de incinte pentru aceste subwoofere !
( proiect sau incinta finalizata dupa preferintele clientului )
Trimit oriunde in toata tara
Comanda onorata de pe o zi pe alta !
YM --> shokaliptiku
tel --> 0742 090 285
Urmeaza preturile !!!
Shokaliptiku 27-09-10 12:17
Re: VAND orice subwoofer SPL DYNAMICS
SPL Dynamics V-250S4
Specifications
Size 276mm ( 10" )
Power handling (RMS/Peak) 300/600 W
Nominal impedance 4 Ohm
Mounting depth 138 mm
Mounting diameter 234 mm
Magnet weight 75 oz
Voice Coil diameter 51 mm ( 2" )
Voice Coil Type/Material SVC / Black Aluminium
Fs 32.6 Hz
Vas 33.9 L
Qts 0.472
Qes 0.543
Qms 3.633
Xmax (lin/peak) 8.5/17 mm
Re 3.2 Ohm
Mms 124 g
BL 12.53 TM
SPL (1W/m) 85.8 dB
PRET : 305RON
Shokaliptiku 27-09-10 12:24
SPL Dynamics V-250D2
Specifications
Size 276mm ( 10" )
Nominal impedance 2 x 2 Ohm
Magnet weight 75 oz
Voice Coil Type/Material DVC / Black Aluminium
Voice Coils connection
series parallel
Impedance 4 Ohm 1 Ohm
Fs 32.1 Hz-32.3 Hz
Vas 31.9 L-32.2 L
Qts 0.465-0.503
Qes 0.513-0.550
Qms 4.457-5.252
Xmax (lin/peak) 10/20 mm
Re 3.8 Ohm-0.95 Ohm
Mms 122 g-122 g
BL 13.505 TM-6.331 TM
SPL (1W/m) 85.1 dB-85.0 dB
PRET : 321RON
Shokaliptiku 27-09-10 12:29
SPL Dynamics V-250D4
Specifications
Size 276mm ( 10" )
Nominal impedance 2 x 4 Ohm
Magnet weight 75 oz
series parallel
Impedance 8 Ohm-2 Ohm
Fs 32.4 Hz-32.5 Hz
Vas 32.4 L-32.7 L
Qts 0.501-0.538
Qes 0.554-0.597
Qms 5.252-5.517
Re 6.4 Ohm-1.6 Ohm
Mms 128 g
BL 8.2 TM-8.687 TM
SPL (1W/m) 84.7 dB-84.5 dB
PRET: 321RON
Shokaliptiku 27-09-10 12:33
SPL Dynamics V-300S4
Specifications
Size 322mm ( 12" )
Power handling (RMS/Peak) 350/700 W
Mounting depth 152 mm
Mounting diameter 273 mm
Magnet weight 80 oz
Fs 30 Hz
Vas 71.5 L
Qts 0.466
Qes 0.528
Qms 3.938
Re 3.2 Ohm
Mms 146 g
BL 12.9 TM
SPL (1W/m) 87.5 dB
PRET: 321RON
Shokaliptiku 27-09-10 12:37
SPL Dynamics V-300D2
Specifications
Size 322mm ( 12" )
Magnet weight 80 oz
series parallel
Impedance 4 Ohm-1 Ohm
Fs30.8 Hz-31.1 Hz
Vas67.5 L-69 L
Qts0.507-0.565
Qes0.574-0.633
Qms4.367-5.295
Xmax (lin/peak)10/20 mm
Re 3.8 Ohm-0.95 Ohm
Mms 135 g
BL 13.49 TM-6.323 TM
SPL (1W/m) 87.7 dB-87.6 dB
PRET: 335RON
Shokaliptiku 27-09-10 12:41
SPL Dynamics V-300D4
Specifications
Size 322mm ( 12" )
Power handling (RMS/Peak)350/700 W
Magnet weight 80 oz
series parallel
Fs30.7 Hz-30.9 Hz
Vas65.4 L-67.2 L
Qts0.553-0.595
Qes0.616-0.664
Qms5.456-5.676
Re 6.4 Ohm-1.6 Ohm
Mms 146 g
BL 18.18 TM-8.586 TM
SPL (1W/m) 87.6 dB-87.6 dB
PRET: 335RON
Shokaliptiku 27-09-10 15:35
SPL Dynamics PRO-250D2
Technical Specifications
Size 250mm (10")
Power handling (RMS/Peak)500/1000 W
Nominal impedance2 x 2 Ohm
Mounting depth150 mm
Mounting diameter 236 mm
Magnet weight110 oz
Voice Coil diameter65 mm
Voice Coil Type/MaterialDVC / BASV
Fs 47 Hz
Vas 10.5 L
Qts 0.624
Qes 0.688
Qms 6.646
Xmax (lin/peak) 13/26 mm
Re 2 x 1.7 Ohm
Mms 188 g
BL 16.6 TM
Sd 347 cm²
SPL (1W/m) 84 dB
PRET: 510RON
Shokaliptiku 27-09-10 15:40
SPL Dynamics PRO-300D2
Size 300mm (12")
Power handling (RMS/Peak) 600/1200 W
Mounting depth 164 mm
Mounting diameter 282 mm
Magnet weight 130 oz
Voice Coil diameter 65 mm
Voice Coil Type/Material DVC / BASV
Fs 32 Hz
Vas 41 L
Qts 0.46
Qes 0.52
SPL (1W/m) 87 dB
PRET: 630RON
Shokaliptiku 27-09-10 15:42
SPL Dynamics PRO-300D4
Size 300mm (12")
Fs 34 Hz
Vas 0 L
Qts 0.52
Qes 0.6
SPL (1W/m) 87 dB
PRET: 630RON
Shokaliptiku 27-09-10 16:05
SPL Dynamics PRO-380D2
Size 380mm (15")
Power handling (RMS/Peak) 750/1500 W
Mounting depth 188 mm
Mounting diameter 353 mm
Magnet weight 160 oz
Voice Coil diameter 75 mm
Fs 31 Hz
Vas 73 L
Qts 0.41
Qes 0.46
SPL (1W/m) 89 dB
PRET: 750RON
Shokaliptiku 27-09-10 16:08
SPL Dynamics PRO-380D4
Size 380mm (15")
Fs 31 Hz
Vas 73 L
Qts 0.41
Qes 0.46
SPL (1W/m) 89 dB
PRET : 750RON
Shokaliptiku 27-09-10 16:12
SPL Dynamics XTR-250D2
Specifications
Size 275mm ( 10" )
Mounting depth 154 mm
Voice Coil diameter 63 mm ( 2.5" )
Weight 10.8 kg
series parallel
Fs 33.5 Hz-34.1 Hz
Vas 18.4 L-18.9 L
Qts 0.319-0.378
Qes 0.355-0.416
Qms 3.142-4.085
Re 3.4 Ohm-0.85 Ohm
Mms 184 g
BL 19.56 TM-8.84 TM
SPL (1W/1m) 84.8 dB-84.6 dB
PRET: 600RON
Shokaliptiku 27-09-10 16:32
SPL Dynamics XTR-250D4
Specifications
Size 275mm ( 10" )
Weight 10.8 kg
series parallel
Fs 32.7 Hz-33.3 Hz
Vas 23.3 L-22.6 L
Qts 0.354-0.392
Qes 0.391-0.432
Qms 3.768-4.236
Xmax (lin/peak) 11/22 mm
Re 6.4 Ohm-1.6 Ohm
Mms 160 g
BL 23.01 TM-11.53 TM
SPL (1W/1m) 85.1 dB-84.9 dB
PRET: 600RON
Shokaliptiku 27-09-10 16:36
SPL Dynamics XTR-300D2
Size 325mm ( 12" )
Mounting depth 170 mm
Mounting diameter 284 mm
Weight 11.3 kg
series parallel
Fs 31.4 Hz-31.7 Hz
Vas 41.9 L-42.7 L
Qts 0.394-0.452
Qes 0.433-0.493
Qms 4.30-5.438
Xmax (lin/peak)11/22 mm
Re 3.6 Ohm-0.9 Ohm
Mms 240 g
BL 20.07 TM-9.26 TM
SPL (1W/1m) 86.6 dB-86.3 dB
PRET: 690RON
